?bad ignition switch cut off all power??
Old Jan 14, 2018 | 09:56 PM
DavidNHarris88's Avatar
DavidNHarris88
Default ?bad ignition switch cut off all power??
Could a bad ignition switch cut off all power?
Battery is good, when I turn key over nothing happens, no starter, no dash lights, headlights won’t even turn on.
It’s a ‘77
Old Jan 14, 2018 | 10:18 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Does the horn work?
Would help if we knew what you were working on.
Old Jan 14, 2018 | 10:45 PM
DavidNHarris88
Originally Posted by Hammerhead Fred
Does the horn work?
The Horn wasn’t hooked up from the get go. Working on a 77 with a manual transmission
Old Jan 15, 2018 | 08:43 AM
Hammerhead Fred
Headlights not working would indicate it's something besides the ignition switch. Start with the basics: Battery cables, ground to frame, fusible links.
Old Jan 15, 2018 | 10:35 AM
DavidNHarris88
I checked the fusible link from the battery to the starter and it is good. Are there others I should check?
Old Jan 15, 2018 | 11:18 AM
TimAT's Avatar
TimAT
Have you checked the connector at the starter extension harness yet? ALL of the power to everything runs thru it.
Old Jan 15, 2018 | 11:24 AM
kansas123's Avatar
kansas123
I lost all power driving down the street many years ago due to a short in the dash, a speaker wire I believe it was. It blew the fusible link right next to the horn relay. Dead to the world she was....
Old Jan 16, 2018 | 04:14 PM
DavidNHarris88
Found the issue, bad spliced wire sending power to the alternator. Fixed the splice, got power back. Thanks everyone for the advice
To ?bad ignition switch cut off all power??
