disconnect engine from trans?
Old Oct 12, 2002 | 11:10 AM
78pace's Avatar
78pace
Default disconnect engine from trans?
going to pull the 350. i know you have to unbolt bellhousing from block,
dont you have to go in thru service plate to disconnect flywheel from torque
converter? its been 20 or so yrs. since i pulled a motor and that was in my mopar. any other words of wisdom would be great thanks :smash:
Old Oct 12, 2002 | 11:59 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: disconnect engine from trans? (78pace)
Yes, you'll need to unbolt the flywheel from the converter. There are 6 bolts(9/16 I think) holding the tranny to the block. Even after removing all the bolts you may have a difficult time separating the block----at least I did. There are two dowels also connecting the block & the tranny. After so many years together mine didn't want to part! :lol:
I had to tap the tranny with a 2x4 to finally separate them.
Old Oct 12, 2002 | 12:40 PM
randy814u's Avatar
randy814u
Default Re: disconnect engine from trans? (1970 Stingray)
Also, you might want to, just as you are sliding them apart, take the time to crawl under the car and take like a piece of wire and put across the converter so it does not fall out and off. :seeya
Old Oct 12, 2002 | 04:56 PM
78pace's Avatar
78pace
Default Re: disconnect engine from trans? (randy814u)
thanks the fun of it all is comong back to me now :D
To disconnect engine from trans?
