I think you need to look for more problems other which piston to buy. That looks like some detonation issues maybe (is it a hypereutectic?) Have you checked all the others??
JIM
^^^This^^^
Two busted ring lands didn't happen at assembly, cylinder wall would be junk by now if that happened.
Also, the top of that pin looks like it's been way hot, looks like baked-on oil.
Lets play the "What If" game.
What if the ring end gap called for, say 0.016.
And for some unknown reason it was set at 0.010.
And what if the bore had a unreasonable taper?
What would happen to the lands?
That's a vey interesting thought. Wouldn't the walls be scored if the ring was wedged into a taper? I didn't see any marks or scrapes on the walls. Damn... I have the oil pan on already. Second guessing is the worst. It's a good thought. Thank you for it.
I just find it hard to believe that damage was done at assembly. Normally a plastic handle or even a wooden handle of a hammer gently taps the piston home. Yours looks like somebody forced a 40 over into the bore with a sledge hammer!
But what if the rings were too tight after warm up . . . . . .
Sometimes things just break because of an unnoticed manufacturing defect. A 500 ppm failure rate is very acceptable in most industries. 5 defective for every 10,000 made.
