Good body glue needed
Old Jan 25, 2018 | 03:21 PM
vettebak's Avatar
vettebak
Default Good body glue needed
Im looking for some advice for some glue
The wheel well came of the main body.
Only the top off it if you push on top of the side you can push it in.
If you look in side of the wheel well you can see they glued it in the factory
At the top there is a gab.
And I have taken out the front headlight brace it came loose on some places. Going to sand blast it and powder coat it.
Then i need to glue it back to the front nose
Any advice of the sort glue to use would be apriciated
Would be nice if its from a brand like 3m
Old Jan 25, 2018 | 04:23 PM
Denpo's Avatar
Denpo
3M 8115, expensive but stick like nothing else. Did my entire front clip with it.
Old Jan 25, 2018 | 04:43 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
You need bare metal to glue to, grind the contact area.
Old Jan 25, 2018 | 06:18 PM
Denpo's Avatar
Denpo
Right, then de-grease everything with acetone and scuff surfaces with some 80 grits.
Old Jan 25, 2018 | 06:46 PM
SB64's Avatar
SB64
Default Adhesive
Fusor 2 part product.
To Good body glue needed
