1979 corvette door hinge spring. Problem
Old Jan 28, 2018 | 10:31 AM
toyfj's Avatar
toyfj
5th Gear
Default 1979 corvette door hinge spring. Problem
I was attempting to install new door hinge spring after putting in new bushings and pins. I put the center of the spring into the groove and drop the top into the hole. My problem arises in that I can push the bottom part of the spring into the d slot without the tool, so there is no pressure on it and it rattles around loose and falls down again. Any idea what I’m doing wrong?
Old Jan 28, 2018 | 02:08 PM
righthanddrive's Avatar
righthanddrive
There are videos online to watch, in order to install the spring correctly.
You need a large bent screwdriver to install it if the ninge is still attached to the door.
Old Jan 28, 2018 | 04:05 PM
Peterbuilt's Avatar
Peterbuilt
Check that the spring is the correct length as seen in Willcox's video.
http://repairs.willcoxcorvette.com/?...&s=door+spring
Old Jan 28, 2018 | 05:26 PM
toyfj's Avatar
toyfj
5th Gear
Default Hinge spring
yeah I watched them appears easy. Lol I have the tool but I don’t need to tension it to get it to go up into the Dstop. So it will not go under tension
To 1979 corvette door hinge spring. Problem
