INTAKE SWAP ON 73 LS4
Old Oct 12, 2002 | 08:40 PM
LIVE4RDO's Avatar
LIVE4RDO
Cruising
Default INTAKE SWAP ON 73 LS4
HI! CAN SOMEBODY ADVISE ME IF IT PAYS TO SWAP STOCK CAST IRON INTAKE MANIFOLD ON MY 73 LS4 454 ON ALUMINUM ONE FROM 69 427 L-36. IS THERE ANYTHING I SHOULD KNOW ABOUT SUCH SWAP? CAN I USE HOLLEY 750 DOUBLE-PUMPER ON THAT MANIFOLD. CAN I ONLY USE THE ONE FROM 69 OR THERE ARE OTHER YEARS THAT WOULD BE COMPATIBLE? DO I HAVE TO MODIFY IT OR IT JUST BOLT ON?
THANK YOU. :smash: :chevy
Old Oct 12, 2002 | 09:57 PM
73 LS-4's Avatar
73 LS-4
Default Re: INTAKE SWAP ON 73 LS4 (LIVE4RDO)
Since I did this swap I'll jump on in. First off the swap is worth the weight loss by itself, you won't believe how heavy the stock LS-4 intake is. The 68-69 L-36 intake is made for a quadrajet and is the only aluminum big block intake that GM made for a quadrajet and a big block with oval ports. Ithink there are actualy 3 different castings for this intake, an early and late 68 and then a 69 casting, I have an early 68 myself. I found the L-36 intake a tad taler then the stock LS-4 intake but not by much and your cowl induction hardware will still clear, mine has a brand new seal and it clears fine. You may lose a tad low end grunt with this intake over the LS-4, but it makes it up in the midrange. The L-36 intake is also much easier to do some port work on since it's aluminum, I took some advantage of this. Don't expect a major power gain on this swap, but you will pick up some power and lose a ton of weight. Now for the modifications, these are realtively minoe little things. Your divorced choke will not work with this intake (unless the later castings were different), I got a divorced choke unit off of a 68 and made a rod for the choke, it works OK, but I just have full choke and none, needs some fine tuning but works good enough for a weekend toy. The other is the water pump bypass hose, for some reason the L-36 intake is shorter in front so you may need a bit longer bypass hose to get it to work. Now for the biggest pain of the swap which is the carb gaskets. The aluminum L-36 intake had an open heat crossover under the carb, so it requires a special 3 part gasket to work, not a big deal, you just have to plan ahead if you plan to pull the carb. Other then that it's a simple bolt on. If you need any more info, just ask :D
:cheers:
Pat Kunz
Old Oct 13, 2002 | 01:36 AM
LIVE4RDO's Avatar
LIVE4RDO
Cruising
THANK YOU 73 LS4!
Old Oct 14, 2002 | 01:13 AM
73 LS-4's Avatar
73 LS-4
Oh yea, here's the casting numbers for you: 3947801, 3919849, and 3937793.
:cheers:
Pat Kunz
To INTAKE SWAP ON 73 LS4
