Engine specs for 72 LT-1
Old Jan 28, 2018 | 04:00 PM
Lloyd Raymond's Avatar
Lloyd Raymond
Default Engine specs for 72 LT-1
Are the engine internals of the 72 LT-1 the same as the 70 LT-1?
Old Jan 28, 2018 | 04:30 PM
Dynra Rockets's Avatar
Dynra Rockets
Less CR to 9:1 (and hardened valve seats)
https://en.wikipedia.org/wiki/Chevrolet_LT-1
R
Old Jan 28, 2018 | 04:57 PM
jb78L-82's Avatar
jb78L-82
1970 LT-1 had 11:1 compression versus the 71/72 LT-1 had 9:1 compression. All LT-1's had solid lifter cams. The 1970 LT-1 is the "real" LT-1. 71/72 LT-1's had the same compression as the later L-82's (9:1) which had hydraulic cams and similar HP (around 250 Net HP for the L-82, 330 Gross HP for the 71 LT-1.
LT-1 cams also had more duration and slightly more lift, apples to apples, solid to hydraulic cam the duration for the Solid cam LT-1 is 234/239, lift .459/.485 from what I can find on the conversion factor versus the L-82 cam of 222 duration and .450/.460 lift
Old Jan 29, 2018 | 07:08 AM
Tonio's Avatar
Tonio
What makes the 1970 the only "real" LT-1?
Old Jan 29, 2018 | 07:36 AM
Dynra Rockets
Maybe "desirable" or "sought after" or "premium worthy" would be better adjectives. the 11:1 CR and extra 40hp is the reason.
Old Feb 4, 2018 | 12:30 AM
zebebad's Avatar
zebebad
My understanding the diffrences in compression from the 70 LT1 to the 71 & 72 was from going from 64cc heads in 70 to 76cc heads in 71 & 72 all eles was the same ....
Old Feb 4, 2018 | 12:34 AM
a striper's Avatar
a striper
Slightly off topic but at least the non-real '72s are self validating real non-real LT-1s
Old Feb 4, 2018 | 02:57 PM
Barry's70LT1's Avatar
Barry's70LT1
A 1970 LT-1 had "dome" pistons. '71-'72 had "flat-top" pistons.
Old Feb 4, 2018 | 05:21 PM
zebebad's Avatar
zebebad
Got it !
Old Mar 30, 2026 | 02:25 PM
1-8-4-3-6-5-7-2's Avatar
1-8-4-3-6-5-7-2
Posted incorrectly
Last edited by 1-8-4-3-6-5-7-2; Mar 30, 2026 at 03:15 PM. Reason: Posted incorrectly
To Engine specs for 72 LT-1
