Why does Penn Grade oil so expensive?
Old Feb 7, 2018 | 04:29 PM
Alwyn678's Avatar
Alwyn678
Default Why does Penn Grade oil so expensive?
Must be good
Old Feb 7, 2018 | 04:31 PM
Alwyn678's Avatar
Alwyn678
Brad Penn oil is higher priced
Old Feb 7, 2018 | 04:47 PM
HeadsU.P.'s Avatar
HeadsU.P.
Quality and extra Zinc.
And purdy bottles.
Old Feb 7, 2018 | 04:50 PM
Alwyn678's Avatar
Alwyn678
And purdy bottles.
Valvoline also have extra Zinc.....but. Does not cost as much? So is the cost for the puuuuurdyyy bottle?
Old Feb 7, 2018 | 05:26 PM
C6_Racer_X's Avatar
C6_Racer_X
Valvoline doesn't have extra Zinc.
The SM rated Valvoline Racing (VR-1) is about 1200ppm zinc at the most. That's marginal for flat tappet cams and lifters. It's literally the lowest number you want to see on your used oil if you do an engine oil analysis when you do an oil change, and that's what you're starting with now with Valvoline "Racing" VR1 oils.
I think the latest blend, with the SN starburst may be even lower than that. It's definitely not any higher.
Brad Penn (Penn Grade 1) is significantly higher in Zinc than that. Its also higher than the old Valvoline Racing SJ/CD rated oil, which actually did have enough Zinc to work in older engines with flat tappet cams.
On old Mercedes Benz V8's that I work on (restoration, maintenance), I've done a half dozen camshaft sets in the past couple years. I'm out of spare used cams and spare used heads for the old 5.6L MB V8's. Another guy I know with a larger MB Specialty shop down in Atlanta reports the same issue, and he's seen a lot of classic (older) MB "driver" cars totaled by camshafts getting wiped out. He's also used up all of his collection of serviceable used parts, and now it's $3 grand or more for the new replacement parts for one of those engines when the camshaft gets wiped out from current spec (SM, SN) motor oils.
VW guys with older (8V and early 16V) engines are in the same boat. I've seen a bunch of those with wiped out cams and lifters. Especially the older solid lifter engines.
If you're running flat tappet camshaft(s), do an oil analysis on your motor oil at your next oil change. If it's less than 1200ppm Zinc or less than 1400ppm Phosphorous at the time you change the oil, you're running dangerously low ZDP levels and you should seriously consider the Penn Grade 1 oil, or a high Zinc additive with your existing oil.
There are a few "cheap" diesel/tractor oils out there that are still "SL" rated, and theoretically might have more ZDP (Zinc and Phosphorous) than the newer oils, but I run Brad Penn (Penn Grade 1) now in anything with flat tappets or "slider" cams.
Last edited by C6_Racer_X; Feb 8, 2018 at 09:25 AM. Reason: Added two missing zeros to the ppm numbers for Zinc and Phosphorous levels
Old Feb 7, 2018 | 05:49 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
FWIW, STP oil treatment labels now claim that they have added levels of ZDDP....
Old Feb 7, 2018 | 06:20 PM
HeadsU.P.'s Avatar
HeadsU.P.
Extra purdy plastic bottle. And easy pour spout? Resealable cap? IDK Never use the stuff.
Lucas Classic Hot Rod oil is my cup of tea.
Old Feb 7, 2018 | 06:29 PM
Dynra Rockets's Avatar
Dynra Rockets
The SM rated Valvoline Racing (VR-1) is about 12ppm zinc at the most.
From the sticky above, the VR1 FAQ and the sticky at Chevelles.com:
VR1 Dino is 1300 PPM
VR1 "Not street Legal" is 1472 PPM
VR1 synthetic is 1180 PPM
Old Feb 7, 2018 | 06:42 PM
jim2527's Avatar
jim2527
You can buy proper flat tappet oils at WalMart if you know what your looking for.
Old Feb 7, 2018 | 07:25 PM
C6_Racer_X's Avatar
C6_Racer_X
OK. First, I obviously left a couple zeros off.
My number was for the street legal Synthetic blend, and it looks like my figure was a little higher than current specs. The VR1 synthetic blend is all I ever see stocked at the local parts places. I haven't seen the "dino" stuff in years, although I haven't looked for it online and I don't know much about the "Not street legal" race oils, even tough that would be my pick from those numbers. I thought that Penn Grade 1 is more than that. For some reason 1500-1600 sticks in my head.
Again, I'd consider 1200ppm to be a bare minimum for an engine with flat tappets. And by "bare minimum," I mean that's what I'm looking to exceed on "worn out" oil right at the point where I'm changing it.
What I do know is nobody who I've switched to Penn Grade 1 on their "classic" MB, VW or Audi engines have wiped out any camshafts. And people using more "normal" street oils have been destroying camshafts in the past few years, even if they religiously change their oil every 3,000 miles/3 months. When I've sent samples in for analysis, the ones wiping out camshafts seem to be low on zinc especially, and phosphorous as well.
Old Feb 7, 2018 | 10:00 PM
Dynra Rockets
I have bought the VR1 dino from Amazon for a few years now. About $45/6.
Old Feb 7, 2018 | 10:25 PM
Alwyn678's Avatar
Alwyn678
The SM rated Valvoline Racing (VR-1) is about 12ppm zinc at the most. That's marginal for flat tappet cams and lifters. It's literally the lowest number you want to see on your used oil if you do an engine oil analysis when you do an oil change, and that's what you're starting with now with Valvoline "Racing" VR1 oils.
If you're running flat tappet camshaft(s), do an oil analysis on your motor oil at your next oil change. If it's less than 12ppm Zinc or less than 14ppm Phosphorous at the time you change the oil, you're running dangerously low ZDP levels and you should seriously consider the Penn Grade 1 oil, or a high Zinc additive with your existing oil.
Thanks for the explanation
Old Feb 8, 2018 | 10:05 AM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
1200 is more than sufficient imo. I ran a Comp XE high ramp flat tappet cam with dino VR-1 ...absolutely no issues! This oil hysteria is so out of control!
Old Feb 8, 2018 | 10:41 AM
BlowAMouse's Avatar
BlowAMouse
For your viewing pleasure... not my not my gospal
http://www.bestsyntheticoilfilter.co...complete-list/
Old Feb 8, 2018 | 11:21 AM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
having had a flat cam on a low low seat pressure
cam, i am worried.
no fun and no better good if all that metal
take a ride in the oil system.
i go overboard i am sure.
Old Feb 8, 2018 | 11:36 AM
cv67's Avatar
cv67
St. Jude Donor '05
flat cams are nothing new is happened every day in the 70s and 80s with factory stuff. Buy a quality core/lifters and dont get stupid with ramp rates
Risky? Maybe....but so are roller lifters coming apart. Build what you want and dont worry about it..I dont believe its all the oils fault bet Im not the only one who installed a cam fired it up and started driving it with no break in? Is oil quality a concern sure, just saying...
Failures Ive had
327/275 GM cam lasted 230k mi
Erson "rv" cam lasted 21 yrs
XFI HR 280 18k mi
XE FT, (3 of them) none made it past 600mi
Unnamed billet solid roller made it to 60 mi, valvetrain didnt.
Not necessarily the brand-
40+ cars most had aftermarket cams none failed all flat tappet except a handful
Anyone see a pattern here?
Old Feb 8, 2018 | 12:50 PM
grumpy73's Avatar
grumpy73
Any advantage in adding Lucas oil additive?
Old Feb 8, 2018 | 03:28 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
From the link above, which is also 540 Rat's sticky:
10W30 Valvoline VR1 Conventional Racing Oil (Silver Bottle) – 103,505 PSI
Zinc: 1472 ppm Phos: 1544 ppm Moly: 3 ppm Calcium: 2707 ppm TBN: 7.6
#122
0W30 Brad Penn, Penn Grade 1 (Semi-Synthetic) – 71,377 PSI
Zinc: 1621 ppm Phos: 1437 ppm Moly: 0 ppm
#124
10W30 Brad Penn, Penn Grade 1 (Semi-Synthetic) – 71,206 PSI
Zinc: 1557 ppm Phos: 1651 ppm Moly: 3 ppm
The Brad Penn have relatively low PSI.
You can order VR-1 Conventional at O'Rielly's and NAPA.
To Why does Penn Grade oil so expensive?
