I'm goin' in
I'm goin' in
Looks like I have a blown head gasket on my stock 81 4 speed. Since I have to change it what are the best things to do to improve the performance without getting far away from stock. I plan to get hooker header sidepipes, perhaps a better camshaft and lifters. Anyone have experience with a newer fuel injection instead of the carb. Let me know what you have done that has worked well.
Mike F.
Mike F.
St. Jude Donor '22
Mike F.
Mike F.
how to
you are dealing with 8.2 compression.
an up point of cr is a must.
so, can you do a complete overhaul?
anyway, good luck
Aftermarket iron heads with 62-64cc chambers to help that 8.2 (really more like 7.8-7.9) CR and masquerade as stockers
St. Jude Donor '22
heads are not really numbers stamped like a block.
2 things heads do.
squeeze the gas.air to a pressure that
gives better explosion.
gets air.fuel in and out of engine.
flow and compression.
done with valve size and chamber size.
then a cam is used to pick when the flow and compression
make power.
2 things heads do.
make power.
visionary (02-08-2018)
I looked at these heads and they are nice. I also noticed the combustion chamber in these are small (60cc and 56cc respectively). Can the stock heads be machined in any way (decking)to get close to the specs these heads have? I'm trying to keep the matching numbers stuff but on this one it's a hard choice because there isn't a whole lot of hp to begin with. Any guess how much hp can be gained with headers, cam, lifters and possibly heads? Thanks!
Those heads look impressive for CARB approved.
Received 3,043 Likes
St. Jude Donor '05
Put the stock ones aside, spring for the aftermarkets with the small chamber. If you spend $ on anything do that,EFI a waste of money unless you just have to have it. Qjets are great carbs.
Side pipes. Emissions in your state? Also, even if emissions exempt, side pipes scream "We don' need no steenking catalytic converters!" Some cops could decide emissions exempt and removing emissions equipment are 2 different things...
As far as stock 72 cc heads... No. You can't make them make any kind of power without being a porting magician. And could never shave enough to get decent compression. Stock 96-2000 vortec heads are a good inexpensive upgrade. Make sure they are vortec and not TBI era heads. You will need a correct intake to match. Aluminum heads would be the best way to go, but more dinero...
Blown head gasket. First you pull the heads and make sure your block deck is good before you buy anything.
^^Exactly what everyone's saying is the gospel, the stock heads are doorstops. Everything done right with good aftermarket ; heads, cam, good intake, and an excellent exhaust, will be close enough that if it doesn't gain a full 100 HP - it will sure feel like it...and then some !
And then there's gears...
St. Jude Donor '11-'12-'13,'19-'20
Assuming you only lost one side, I would do a leak test on all the cylinders on the good side. I've seen many attempts to place new sealed small chamber heads on a worn bottom end and quickly end up with blow-by in a cylinder or two. Proceed with caution!
http://www.compcams.com/Company/CC/c...x?csid=73&sb=2
..and the comp 260HE is also "carb legal".
Mike F.
Mike F.
