Tilt/T column problem need help
Old Feb 13, 2018 | 08:36 PM
Averystingray75's Avatar
Averystingray75
Default Tilt/T column problem need help
I have ‘75 corvette and a tilt/telescopic steering colum that has a lot of play. I have no experience with steering column besides fixing my turn signal switch.
I need to know WHAT PART To replace to fix this
Colum flexes/ sloppy at joint in picture
I’ve googled and looking into issue
Probably from years of “pulling” myself into vehicle
I want to fix before spring but I don’t know what actual part I need to replace the name etc or what’s actually wrong and what’s involved getting to it to replace it.
Old Feb 13, 2018 | 09:17 PM
vbgod1's Avatar
vbgod1
Won't promise on a 75 specifically, but on my 78 and most all GM's I have seen, there are torx head type bolts down there that loosen with age. Cure is to disassemble down to it and tighten them.
Old Feb 13, 2018 | 09:35 PM
Gordonm's Avatar
Gordonm
I have rebuilt many of these and most of the time it is the Torx head bolts loosen up.
Old Feb 13, 2018 | 09:51 PM
'75's Avatar
'75
If you do a google search for Jim Shea, you will find his site with all kinds of diagrams and repair instructions for our steering columns.
http://jimshea.corvettefaq.com/
Old Feb 13, 2018 | 09:57 PM
Averystingray75
Any pictures, names or info on how far down they are located what parts they go thro Go? Or keywords to search for?
Old Feb 13, 2018 | 10:48 PM
Peterbuilt's Avatar
Peterbuilt
http://jimshea.corvettefaq.com/?p=1009
Old Feb 15, 2018 | 05:04 PM
Duke94's Avatar
Duke94
Originally Posted by Peterbuilt
You have to get to here. Pretty much everything has to come off.
To Tilt/T column problem need help
