Corvette Power Antenna
Old Feb 15, 2018 | 08:31 AM
reholloway's Avatar
reholloway
5th Gear
Default Corvette Power Antenna
I have a 1980 Corvette and was looking for a power antenna relay. Is it true that they have been discontinued? How do I get one and what do I do to get my power antenna working without the relay? Also need a wireing diagram for the same car of the console to the power antenna.
reholloway@live.com
Old Feb 15, 2018 | 10:06 AM
Moved to C3 Tech.
Old Feb 15, 2018 | 10:21 AM
BKarol's Avatar
BKarol
Can contact Willcox:
http://repairs.willcoxcorvette.com/1...elay-location/
Old Feb 15, 2018 | 12:22 PM
lvmyvt76's Avatar
lvmyvt76
you are asking quite a few questions, how long have you had your corvette?
replacement antennas are buyable, they may not be the exact copy, therefore you may have to do some modifying, or ask corvette junk yards for a take off of an another car. They can be rebuilt, some of the forum members can do that. Go to parts section and put an ad in for all of this. Can yours be rebuilt??? what is wrong with it??? I added a motorized antenna to my 76(not available in 76), did away with the standard one(hard to use with a car cover).
Old Feb 15, 2018 | 04:53 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Why do you think it's the relay?
Usually it's the nylon cable within the antenna that breaks. Can you pull it up by hand?
I have an nos 78-79 relay available for $35 shipped. Basically same as 80-82 except the housing.
Or go on ebay and search GM antenna relay and purchase one for any 78-82 GM car. Swap the housing with your existing relay.
Old Feb 15, 2018 | 05:00 PM
KapsSA's Avatar
KapsSA
Pic shows location for 78-79 under the console but you can see the wires. 80-82 is in the jack compartment.
Green/White/Gray goes to the antenna. Orange is constant hot, yellow is the trigger wire from the radio that tells it to go up and down. Black is ground.
Old Jun 5, 2018 | 09:27 AM
John Vance's Avatar
John Vance
Default Thanks tha was helpful
yep
Originally Posted by KapsSA
Pic shows location for 78-79 under the console but you can see the wires. 80-82 is in the jack compartment. Now if I had s parts picture for the other things under the center consoleGreen/White/Gray goes to the antenna. Orange is constant hot, yellow is the trigger wire from the radio that tells it to go up and down. Black is ground.
To Corvette Power Antenna
