700r4 first to second blow shift ?
Old Oct 13, 2002 | 11:53 PM
faster69's Avatar
faster69
Default 700r4 first to second blow shift ?
Maybe some of you that run a 700r4 in your car can help me out. My trans is blow shifting from first to second gear under full throttle - { I shift manually when I'm racing } The trans is out of a 84 vette and has been rebuilt with all the hi perf. up dates. I have had other 700r4's in hi perf. applications and never seen this, I'm woundering if my trans is taking a dump? thanks, Rick
Old Oct 14, 2002 | 01:07 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: 700r4 first to second blow shift ? (faster69)
Blow shifting ?
For those of us who are not racers, can you explain that term? You may get more help that way.
Old Oct 14, 2002 | 01:27 AM
faster69's Avatar
faster69
" blow shift" slang for the trans shifting to second even though the selector is still in first. for example, the 400 turbo. put the shifter in first gear hit the load pedal and the trans will shift to second even though you did not move the shifter. the 350 turbo will not do this. it will take all the rpms you wish to give it. Until lately, I didn't beleive the 700r4 would blow shift { I think the reason it got this name is because the trans build so much pressure it shifts "automatically" } what does your trans do ??? :cheers:
Old Oct 14, 2002 | 01:33 AM
mrvette's Avatar
mrvette
IMO, most all the 700's do that, shift 1-2 regardless of lever positiion, and really I think it's to save engines....on account of 3'1 first gear ratio....
I hear tell of trannies that are not supposed to do that, but in fact I have never seen one myself.....
my tranny does that, but when I had the valve body apart, I saw the first gear shift valves were blocked off by aluminum slugs....not moving, no springs...just all blocked off....so I dunno...wasn't part of the shift kit, apparently...
GENE
Old Oct 14, 2002 | 03:40 AM
aharte's Avatar
aharte
My 700r4 never shifts out of the gear I put it in up to at least 6000 rpm. I think it might be a little modified but I'm not sure. Its shift points suck otherwise (if not manual-shifting). I end up in 4th gear at 40-50 mph with normal driving (3.08 rear).
Old Oct 14, 2002 | 08:27 AM
dman535's Avatar
dman535
Default Re: 700r4 first to second blow shift ? (aharte)
My 700r4 only shifts when I tell it to. I have held first gear to 6500 rpm. I do have a shift kit installed.
Old Oct 14, 2002 | 11:23 AM
gkull's Avatar
gkull
Default Re: 700r4 first to second blow shift ? (dman535)
I had an art Carr racing full manual 700 and it wouldn't shift unless you did. I now have a Art Carr racing 700 that I can't put into first gear manually. I place the selector in 2nd at a dead stop and it does a 1-2 shift on it's own regulated by what govenor I have installed. I have a 6800 for racing and a 5000 for street driving.
I also have a 4.11 rear and it only stays in first for a second or so before shifting. First is very worthless even with 10 inch slicks
Old Oct 14, 2002 | 11:39 AM
Fevre's Avatar
Fevre
Had a buddy 'blow shift' my 74 Regency 98 while in 1st gear shifter position. And it never shifted into 2 again, would just rev real high in first then jump into 3rd.
Old Oct 14, 2002 | 01:25 PM
Jvette73's Avatar
Jvette73
Default Re: 700r4 first to second blow shift ? (Fevre)
I got a rebuilt 700r4 in my truck and it will stay in first as long as i hold it there.
To 700r4 first to second blow shift ?
