383S fuel pressure.
Old Feb 19, 2018 | 01:11 PM
jhopper408's Avatar
jhopper408
Default 383S fuel pressure.
I have 77 383S. I have a 650 Holly double pumper. It has a pressure gauge on the fuel line. What should the pressure read? I just bought the car in the fall, don't know anything about fuel pressure.
thanks
John.
Old Feb 19, 2018 | 01:15 PM
cv67's Avatar
cv67
St. Jude Donor '05
Are you having issues, what fuel pump do you have on there now?
I wouldnt run more than 8 on a holley
Old Feb 19, 2018 | 01:41 PM
Gordonm's Avatar
Gordonm
6 to 8 depending on what carb you are running.
Old Feb 19, 2018 | 01:43 PM
jhopper408's Avatar
jhopper408
I don't know what fule pump is on there. But it runs about 8 lbs.
Old Feb 19, 2018 | 01:44 PM
jhopper408's Avatar
jhopper408
It's a 650 Holly double pumper. With no issues.
Old Feb 19, 2018 | 01:58 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I have a 650 Holley DP and have the fuel regulated to 6-1/2 psi. Its should be simple enough to turn it down to 6 psi give or take a 1/2 psi. Some will say to run it between 5-7 psi. 8 is over what Holley recommends I do believe.
Old Feb 21, 2018 | 03:26 PM
fishslayer143's Avatar
fishslayer143
check the pressure at 3000 rpm.. 7 psi max
To 383S fuel pressure.
