73 A/C high pressure
Old Feb 19, 2018 | 08:50 PM
CarlGregerson's Avatar
CarlGregerson
Default 73 A/C high pressure
73 Stingray , I have replaced the compressor, VIR , an the condenser. when I charge it with the recommended amount of 134 I'm getting readings of close to 400 on the high side and 50 on the low side. Any ideas why ?
Old Feb 19, 2018 | 09:52 PM
mortgageguy's Avatar
mortgageguy
Go to autoacforums.com they will have your answer.
Old Feb 20, 2018 | 09:16 AM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
did you pull a vacuum on the system prior to charging?
How are your radiator seals, are they in good shape and all in place?
Are you using the OEM radiator fan or electric, if the OEM is the fan shroud in place and in good shape.
All of the items mentioned if not correct will cause high head pressure.
Neal
Old Feb 20, 2018 | 10:11 AM
VERYSOON's Avatar
VERYSOON
That pressure reading, high low and high high, would make me suspect the expansion valve in your vir is stuck open. What was the outside temp when you did your testing? What was the static pressure, i.e., compressor not running?
(I know you are using a new vir.) Other than being overcharged, thats all I can figure could be wrong.
Good luck!
VS
Old Feb 20, 2018 | 10:58 AM
chevymans 77
air in the system and poor air flow across the condenser will also cause these issues
Neal
Old Feb 20, 2018 | 04:29 PM
redcruz1120's Avatar
redcruz1120
St. Jude Donor '09
I had same issue but with electric fans. I had to install a Trinary switch to make fans come on with AC compressor and pull air thru condenser right away.... But that was for a Electric fan set up. If you have a mechanical fan and clutch, you might want to make sure your clutch is good.
Old Feb 20, 2018 | 08:17 PM
CarlGregerson
Default Vir
Good luck!
VS
If the VIR is stuck is there a way to break it loose? the temp was 70 degrees and the compressor was running
Old Feb 20, 2018 | 10:27 PM
chevymans 77
Typically if the expansion valve is stuck open you will see a high suction pressure and a low head pressure. Being there was a large difference in pressures I don't think it is a stuck expansion valve.
How much 134a did you put into the system?
Did you pull a vacuum prior to charging?
Is it cooling any at all?
Neal
Old Feb 21, 2018 | 04:21 PM
VERYSOON's Avatar
VERYSOON
I am attaching some possibly applicable troubleshooting pages from my trusty old 280ZX factory manual.
As chevyman points out, air in the system could cause your problem.
Don't know how to test the vir x valve but if it is stuck open you should at least get some cooling. I bet its something else since its new but stranger things have happened. Part of the fun?
Also, too much oil can cause your high low and high high reading.
Was that pressure reading at 2000 rpm?
Keep at it. I rebuilt my 69 factory a/c (stayed with R12) and found it very cool to have A/C this summer in Texas.
To 73 A/C high pressure
