TH350 fluid leak from speedometer cable
Old Feb 21, 2018 | 12:52 PM
BKbroiler's Avatar
BKbroiler
Default TH350 fluid leak from speedometer cable
I hadn't really looked at my 77 for a few months. I jacked it up to start a little routine maintenance and I noticed a small puddle of trans fluid. It was dripping off the trans mount. Looking up I can see fluid on the cable fitting where it threads onto the gear holder at the back of the trans. I have to remove the trans mount to get at that. I'm just wondering, is there a seal or something there that might need to be replaced?
Old Feb 21, 2018 | 01:01 PM
MelWff's Avatar
MelWff
here is a an example of the seal kit
http://www.classictransmissionsoluti...iABEgIg9PD_BwE
Old Feb 21, 2018 | 01:04 PM
CanadaGrant's Avatar
CanadaGrant
I just did the same with my wife's 78. You don't have to remove the cross member. Just unscrew the speedo cable then remove the 7/16" bolt holding the gear cover on and remove that. Her problem was a combination of 2 things. There is an seal inside the metal holder that was cracked and the speedo gear itself had a worn shaft. I replaced both.
Old Feb 21, 2018 | 02:26 PM
REELAV8R's Avatar
REELAV8R
On my 77 even after seal and O-ring replacement it still wanted to seep.
I ended up putting in a larger cross section O-ring making the "bullet" tighter in the hole where it goes into the transmission to get that to stop seeping.
A new seal also did not last very long, about a year. Seems it does not grip the speedo gear shaft very tightly even when new with a new speedo gear drive.
So on that I shoved an appropriate sized o-ring inside the cavity on the reverse side of the seal making it grip the speedo gear drive shaft tighter. That has been in there for about 5 years now.
Old Feb 21, 2018 | 02:47 PM
BKbroiler's Avatar
BKbroiler
Thanks for the quick help guys.
MelWff - I checked that website and ordered a new bullet, seals, holder tab and bolt. $23, free shipping, not bad. Thanks again.
Old Feb 23, 2018 | 11:07 AM
Big2Bird's Avatar
Big2Bird
Clean the hole well, and smear some "Right stuff" silicone around it before you jamb it in. Stopped my leak .
Old Feb 23, 2018 | 12:25 PM
BKbroiler's Avatar
BKbroiler
Thanks. Yeah I want to stop the leak on the first attempt. I had to remove the bracket under the trans mount since I have dual exhaust and a drive shaft loop. Couldn't reach the cable holder any other way.
Old Feb 23, 2018 | 02:50 PM
HeadsU.P.'s Avatar
HeadsU.P.
I would use great caution putting any RTV in a place that could plug up the tranny filter or any of the billzillion orfices in the trans valvebody. Everything will come to a screeching halt.
To TH350 fluid leak from speedometer cable
