Help with alternator wires 1979
Old Feb 24, 2018 | 10:39 PM
r16678's Avatar
r16678
Default Help with alternator wires 1979
I have a 1979 and can not remember how to hook up the wires that I believe go to the alternator. From the driver side of the car I have the wires in the photos below. They line up next to the alternator. Appreciate any help.
Old Feb 24, 2018 | 11:40 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
The black one with the ring goes to a bolt in the back side of the alternator, look for a threaded hole, hose support bracket also attaches here.
Red with big boot on it goes to an insulated stud on the back side, look for I believe a red insulator at the base of the stud.
2 wire connector goes into the top(if alternator is clocked correctly).
Green with connector is for water temp gauge between left side first and second spark plugs.
That short connector is for under hood light.
Old Feb 25, 2018 | 09:07 AM
r16678's Avatar
r16678
THank you very much I will try hooking them up today
To Help with alternator wires 1979
