I've seen several listings that state drive shafts on an '80 vette are different transmission vs Diff ends, one being spicer 1310 and the other 1330. However, I just pulled mine off and they both meet the 1310 dimension (1.0625 cup, 3.220 width). Does this sound correct? I bought the car new and while the half shaft u-joints were replaced at one time (they are the 1330's given the 3.625 width), the drive shaft joints should all be original.
If you have a manual transmission the half shafts u-joints will be 1350s.
An automatic will have the smaller 1310s.
How's the rear end work going Vince vette 2?
Thanks for the confirmation.
I assume you meant the smaller 1330's on the half shafts - mine is an automatic and that's what I measured them to be.
The rear end is out and just sitting on a bench for now. In the interest of time I've decided to have a standard rebuild done on it. Then I can take my time collecting all the parts to swap it to an Eaton in a couple year. Not a cost effective decision nor the least work as it means pulling it all out again in a few years. But it will have me back on the road this spring, and at 59 hopefully I'll retire in a couple years and can spend more time on it.
I am curious though, I pulled the bolts our of the bearing caps and the caps are stuck pretty well to the housing, is there a trick to getting them to come out, or does it just take a good whack? I only want to pull the driver's so I can dimension it in the event I want to have a replacement steel unit made.
Yep damn bro. I misspoke. I'll correct it before I catch hell.
That I can't answer. I have worked on a lot of mechanical things but I leave the rear end gear work to the experts.
By the way I just turned 60. Retired early and I'm loving it.
