C3 Auto to T5 Swap
Old Feb 28, 2018 | 03:55 PM
Xfactor's Avatar
Xfactor
Cruising
Default C3 Auto to T5 Swap
Hello everyone, so I am looking into doing a t5 Chevy swap and I have read a lot of posts about the swap itself. My question is what is the best trans to look for meaning year, v8 vs v6. So far I have found a 89 Iroc trans that comes with bell housing flywheel ... etc the whole set up pretty much, but also I have found a 96 firebird V6 trans. Anyone has any suggestions on what is the better choice to go with or if there is even a better choice to go with other than T5. Any input would be appreciated.
Old Feb 28, 2018 | 03:59 PM
Dynra Rockets's Avatar
Dynra Rockets
A 'U' code WC unit.
http://www.britishv8.org/articles/bo...t5-id-tags.htm
Search "1352-176" in this forum and you will get a lot of threads.
Old Feb 28, 2018 | 06:56 PM
derekderek's Avatar
derekderek
I know of one, I think.
Old Feb 28, 2018 | 07:32 PM
Xfactor's Avatar
Xfactor
Cruising
Are the older versions better to install?
Old Feb 28, 2018 | 07:36 PM
derekderek's Avatar
derekderek
Externally the Camara ones are all the same. The 87-92 are rated a little higher in torque they can handle. But Trans people say there is no real functional difference in strength between the world class and the older type.
Old Feb 28, 2018 | 07:44 PM
derekderek's Avatar
derekderek
It is easier to find mustang trannys. But they need a 200 buck adapter to fit chebby motors and 26 spline ford driveshaft. And there is no yoke in 26 spline ford that can be unbolted to remove u-joint. So you end up assembling the front u-joint in place on the car. Apparently not fun. The v6 Trans have too deep first gear. 3.75 to 4.0 means you are hitting second in 2 or 3 car lengths.
Old Feb 28, 2018 | 07:55 PM
Xfactor's Avatar
Xfactor
Cruising
Great thank you for the feedback, I found an 89 Camaro IRocZ that I will be looking at it this weekend. The car was involved in a crash so the guy is parting it out. He s letting me take anything I want including flywheel, starter , slave cylinder. I am thinking of taking the pedals also maybe I can fit them. Is there anything else maybe I should take from the car since I get this opportunity?
Old Feb 28, 2018 | 08:32 PM
Dynra Rockets
Depends on what you mean by "older".
If you mean the '87-88 version vs the 89-92 then yes, the older one are slightly easier as you don't have to adapt the electric speedo.
If you mean the current Tremec 5 speeds verses the 87-92 then, no, they are the same level of effort. (other than rolling your own vs a $$ kit)
Old Feb 28, 2018 | 09:48 PM
Xfactor's Avatar
Xfactor
Cruising
It looks like i will be going witha 89 t5 I guess the kit below should do the trick
https://rover.ebay.com/rover/0/0/0?m...2F311424946222
Old Mar 1, 2018 | 12:13 PM
derekderek's Avatar
derekderek
All v8 camaro-firebird 92-older are cable speedo. If you have found an 89 T5, be sure it is a WC unit. Just cut it was in an 89 doesn't mean it didn't leave factory in an 85, or even a v6 car. Check tag number. If no tag verify front counter gear bearing and check gear ratio in 1st and 5th.
Old Mar 1, 2018 | 02:47 PM
Xfactor's Avatar
Xfactor
Cruising
Will do I will be going there this saturday to check it out.
Old Mar 1, 2018 | 04:41 PM
derekderek's Avatar
derekderek
Okay, you have probably already done enough homework that you can tell a world-class from a non world-class at a glance. But just in case. Here.http://www.garage-scene.com/t5-into-...dentifying.htm
Old Mar 2, 2018 | 05:38 PM
Xfactor's Avatar
Xfactor
Cruising
Hey guts so I got the trans code and it is a WG 13 52 072 it is a U code but i cant fgure out is it a wc or not?
Old Mar 2, 2018 | 05:43 PM
derekderek's Avatar
derekderek
Got a pic of the front, or closeups of anywhere on the sides?
Old Mar 2, 2018 | 05:53 PM
derekderek's Avatar
derekderek
If that is the tag number, it is an 85 non-WC. How much he asking? A non-WC is a 300 dollar trans. The WC units are worth more, but only rated about 20 ft/lbs more torque. The trans builders I have spoken to say there is no real difference in what the trans will take, WC or NWC.
Old Mar 2, 2018 | 06:26 PM
Xfactor's Avatar
Xfactor
Cruising
He is asking $350 for everything pressure plate and flywheel.
Old Mar 2, 2018 | 06:28 PM
Xfactor's Avatar
Xfactor
Cruising
This is the picture I got
Old Mar 3, 2018 | 02:49 AM
derekderek's Avatar
derekderek
Ok, 85 Camaro NON world class. 85. I think that is the last of the 2-piece seal engines. Flywheel will work. I know of a 89-90 firebird trans. 500 plus shipping upstate new york. I got one shipped to me for 65 bucks ups ground. 80 lbs 200 miles. How do you drive? These are not bullet-proof. You dump clutch and see how far you can smoke tires in 2nd and 3rd any T5 will be in pieces on the street behind you. I don't think the angled bell housing is a great idea in corvettes though.
Old Mar 4, 2018 | 09:39 AM
c3_dk's Avatar
c3_dk
I agree, if you go down the T5 road, then the 176 is a good ratio transmission, and it is a WC transmission. The next best thing, with a 176 transmission, is a 3.70 or 4.11 rear.
That in my mind will be the best driveline.
To C3 Auto to T5 Swap
