Need help identifying this little rubber boot!
Old Mar 1, 2018 | 08:56 PM
74VetteAZ's Avatar
74VetteAZ
Default Need help identifying this little rubber boot!
We are restoring a 74 big block with Manual transmission. I found this little rubber boot on the ground under the right side front--I have no idea where it belongs! Does anyone happen to know?
3 pictures attached!
Please let me know if YOU know! Thanks so much!
Old Mar 2, 2018 | 12:19 AM
Hammerhead Fred's Avatar
Hammerhead Fred
Really looks like a primer bulb for a small engine (weed eater?)
Old Mar 2, 2018 | 12:31 AM
Rodnok1's Avatar
Rodnok1
Old Mar 2, 2018 | 08:30 AM
jimvette999's Avatar
jimvette999
That is not a vette part IMO
Old Mar 2, 2018 | 11:59 AM
OldCarBum's Avatar
OldCarBum
On Harleys, there is a brake bleeder cover that looks something like that which keeps dirt/dust out of the bleeders. Just a thought.
Old Mar 2, 2018 | 06:56 PM
Sayfoo's Avatar
Sayfoo
A block off grommet for a body hole?
Old Mar 2, 2018 | 10:01 PM
Crimson Thunder's Avatar
Crimson Thunder
Zerk cover?
Old Mar 3, 2018 | 03:58 AM
marshal135's Avatar
marshal135
Veteran: Marine Corps
Definitely fell off the caliper bleeder.
Marshal
Old Mar 4, 2018 | 12:07 PM
vettfixr's Avatar
vettfixr
All good guesses but all wrong. That part goes on the seat belt interlock relay located on the right side near the blower connection. This relay was used to reset the system in case you couldn't get the car started. It just pushes in the hole on the top of the relay to cover the pushrod.
Old Mar 4, 2018 | 02:19 PM
74VetteAZ's Avatar
74VetteAZ
Thanks so much - I would never have found that - you guys are amazing!!
Old Mar 4, 2018 | 02:43 PM
vettfixr's Avatar
vettfixr
For everyone else, I uploaded a pic of this part. It was a one year only so most folks don't know about it. Here's the pic
This is the seatbelt interlock relay on a 74
Old Mar 6, 2018 | 09:13 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I have a 74 in my shop right now.. and that has to be correct! Although I've never seen the rubber button come loose from the relay, it sure looks like it has.
Willcox
Old Mar 7, 2018 | 10:29 AM
vettfixr's Avatar
vettfixr
I've knocked it off a couple times working on the relay. My relay went bad and I couldn't find a replacement. I ended up going through the wiring diagram and figured out how to jumper the relay internally. Now I don't have to worry about getting stuck in the bank drive thru with a car that won't start. That was a fun day.
To Need help identifying this little rubber boot!
