Exhaust temps
Old Mar 2, 2018 | 02:51 PM
Sayfoo's Avatar
Sayfoo
Default Exhaust temps
I hit my headers with my infrared temp gun right at the heads and there is a difference in temp. I'm sure that this is a product of differences in the intake--stock carb and manifold, '69 427/390--and the exhaust bends, coolant flow, etc., and I'm wondering what a normal spread would be. Measured after extended fast idle with normal water temp.
#1 cylinder=675 deg F 2=720
3=720 4=685
5=805 6=815
7=860 8=840
Look ok to you?
Old Mar 3, 2018 | 01:49 PM
Sayfoo's Avatar
Sayfoo
No thoughts on normal temp spread???
Old Mar 5, 2018 | 03:16 PM
MelWff's Avatar
MelWff
best guess is most people dont do this other than perhaps when an engine is being dynoed with headers.
Old Mar 5, 2018 | 03:38 PM
v2racing's Avatar
v2racing
The 4 front cylinders are closer the to carbs primaries than the rear 4 and the temps seem to show the fuel distribution differences. Under a WOT pull, the individual cylinder temps would probably be very different than at idle.
With a stock carb and manifold, there is not much you can do about fuel distribution. If it's running good, just drive it and don't worry about it.
Mike
Old Mar 6, 2018 | 09:29 AM
bashcraft's Avatar
bashcraft
A Holley carb with 4 corner idle could take care of this, but the temps at idle don't mean a lot. As was said WOT temps will be different and that's what matters.
I have a Holley 950 HP with 4 corner idle on my 502.
Old Mar 7, 2018 | 05:03 AM
myohpe@gmail.com's Avatar
myohpe@gmail.com
Exhaust temps you listed are all within 20% of each other. Normal mostly. What you look for measuring header pipes is a big difference, that shows problems. If you have 700-800 degrees on 6 or 7 pipes, but 1 or 2 pipes measures 200 or 1200, you got trouble. Checking spark plugs is the best way to diagnose how your individual cylinders are running. Plenty of info on the internet on plug coloring and tuning.
Old Mar 7, 2018 | 03:35 PM
bazza77's Avatar
bazza77
3=720 4=685
5=805 6=815
7=860 8=840
Look ok to you?
Yeah looks OK , I remember with my tripower idling it didn't see as big of a difference but my gun could also register the spike when the exhaust valve opened .
Old Mar 7, 2018 | 03:42 PM
Grumpy 427's Avatar
Grumpy 427
The only time you would typically check those is to see if you had a dead hole.
Old Mar 7, 2018 | 03:52 PM
derekderek's Avatar
derekderek
Okay, so the front cylinders idle mixture is better and the back cylinders idle mixture is somewhat lean and that's why they read hotter?
Old Mar 7, 2018 | 04:07 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
could have to do with the way water flows thru
block
front cyl get colder water thus changing
cyl temps.
i see no problem with your posted temps.
To Exhaust temps
