At wits end with my 79 corvette
Problem: stumbles and sputters out at ~1800-2000 RPMs and the engine won't rev any higher in gear.
I rebuilt the carter quadrajet 4mv that was on it initially about 3 times, same result. Adjusted its air valves, even endeavored with the APT feature to no avail.
Replaced the fuel pump, same result.
Bought a remanufactured rochester quadrajet from autoline recently, installed it. Same result.
Throughout all of this, I was under the presumption it was a timing/ignition issue as well. All new sparkplugs, firing order is correct, Checked all the wires, they work fine.
Tried various different combinations of initial timing/full centrifugal advance. Best running now at 16 initial 36 total, but the sputtering never seems to go away. Played around with the idle air mixture screws, same result.
Put all sorts of different combinations of distributor springs on, same result
Removed EGR valve and sealed the hole, same result.
I don't really know what I am doing here as this is my first muscle car, but I've been trying to get this motor to run good for almost two years, not even the mechanic could figure it out, he said I needed a new carb and fuel pump and obviously that's not the problem since I've just now replaced them.
The exhaust has no cats
I unhooked the EFE thing and made sure it was working.
I plugged up all the vacuum ports and changed out vacuum lines. Don't think I have a vacuum leak, but it sure seems like it? The only skeptical looking fittings are those choke heat tubes, but to my understanding those have nothing to do with engine vacuum?
I don't want to goof around with the secondary air valve spring since this carb should be set up properly, there's plenty of tension it's not sloppy.
Is it a metering problem? Should I play around with the idle air mixture screws some more? Should I look for another possible vacuum leak? Out of ideas
Long post!!!
Thanks!
Long post!!!
Thanks!
Thunor (03-05-2018)
Can you borrow a known good HEI distributor to swap in? Probably the fastest way to eliminate cap, rotor, and module. What about plug wires? I think you have pretty much eliminated carburetion as a possibility.
Thunor (03-05-2018)
Thunor (03-05-2018)
I have not, but I'm sure that component is probably ruined as the gas that I siphoned out of the car when I first got it was quite disgusting. The fuel gauge doesn't work. I blew compressed air through the fuel lines to make sure there wasn't a blockage and air flows freely. The fuel filter is near the carburetor, and I can see the fuel going to the carb.
Dropping the fuel tank might be in order soon though.
No sadly, I don't have any car friends. I did check all the wires with a spark plug wire tester though.
This might be it, but I don't know where this is located on the corvette? Is it near the distributor? I don't see anything like it.
Thanks for all the replies!!
Don't need to drop the tank all the way
Brian,
Thunor (03-04-2018)
They are subject to deterioration from heat, and it might be your problem It's very easy to change as well.
PS - I know you said the wires tested OK, but unless they are fairly new you might want to replace them in any case. In my 80 I ran the original wires about 10 years. At that point the thing would cough and sputter just as it was hitting the shift point under hard acceleration, usually in the high 4000's, then once it managed to shift it would be smooth again until getting into the higher RPM's. Just a thought.
Brian,
Ok friends, I removed it and I'll replace it tomorrow.
Question, if I timed it with a bad ignition control module, will I have to time the engine again with a properly functioning ICM?
Thanks everyone!!
Thanks everyone!!
Unlikely. Just swap the modules. Make sure you apply plenty of silicone grease to the bottom of the module before you install it. It is there to facilitate heat transfer so the module doesn't overheat. That's what kills them.
Thunor (03-05-2018)
Do as Brian says. Old cars, cruddy tanks. You have fuel at the carb, but not enough volume at speed. Better to pull the tank too. A simple rinse prob won't make a long term fix.
Man i have chased those demons! Back and forth. Good idle, crappy wot...adjust, good wot, crappy idle. Never did get it to run right with poor fuel delivery.
Boy that sender corrosion is incredible. I just pulled mine out of my 80 yesterday as I pulled the tank to get the build sheet while it still existed. I figured I would clean things up will it was out. The sending unit looked perfectly fine. and the actual plastic tank inside looked find. I know everything is original since I'm the original owner. And mine also sat for more than a decade before I started on it a couple years ago.
