Manifold Pressure at WOT?
Looking for input from folks who either have seen or recorded the manifold pressure at WOT. I recently had the car on a dyno and also hooked up a MAP sensor to me LM-1 data logger.
I noticed during a dyno run at WOT my manifold vacuum was about 3 to 4"hg of vacuum. I know when people talk about WOT it is always said one should be near 0" of vacuum. Maybe in a perfect world but I wonder what is typical with these engines. My vacuum climbed to near 5" on the 6500 rpm run. The car was originally tested with a 950 cfm carb. I swapped to a 830 body with annular boosters. The cars street manners have improved and feels more responsive down low. I am thinking about running the car with the 950 carb to see if there is a meaning difference in the numbers.
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,926 Likes
For peak power, we shoot for about .5" Hg at WOT. More vacuum than that, such as your 3-4", indicates restriction on the inlet side, such as an undersized carb or restrictions in inlet airflow. Here is an example of a pretty good dyno test on an engine I ran recently. Note the "Man Vac" column:
Lars
Lars
The following 2 users liked this post by lars:
C6_Racer_X (03-11-2018),
KJL (03-11-2018)
Thanks Lars!! I will run it next week with the 950 and a freshly cleaned K&N filter and see what she does.
Adding a bit of relevant math to the discussion, IIRC, the "CFM" rating of a carb is at a vacuum level in the manifold of 1.5" Hg for 4 barrel carbs, and 3" Hg for 2 barrel carbs.
And somewhere in the back of my mind, theres a memory (perhaps inaccurate) that a 350CID engine draws approximately RPM/10 CFM at 100% volumetric efficiency.
I just pasted in a dyno printout in my post above of a run we did recently. Note the manifold pressure column.
With an air cleaner in place you might not get into the .5" range. We run our dyno tests with a bell-mouth inlet and no air cleaner.
Lars
Lars
Thanks for the data. I am surprised to see how low. I know I am probably splitting hairs here but I have an opportunity to learn something and share with others regarding these large displacement small blocks. I am also running 34 degree advance and would like to try 36 in a separate run.
If you have good heads, you will see power drop at 36 degrees. Good aftermarket heads on a big-cube small block will produce best power at 32 - 34 degrees total. (My experience testing 420 - 427 small blocks with aftermarket aluminum and iron heads)
Lars
Lars
Thanks!
I like keeping the IFRs in the carb "square" so all 4 corners have the same idle metering characteristics.
Lars
Lars
This is just an alternative thought to increasing inches of vacuum as rpm's rise. You stated up to 5 @6500.
annular boosters are a restriction to flow compared to a down leg booster. The restriction rises with air flow (rpm ) on a flow bench it can record say 18 less cfm at lower flow and higher than 60 cfm on the top end
a cheaper alternative might be down leg boosters right now I'm running down leg on my 830 demon. I drove around with a big vacuum gauge duct taped to the windshield. I'm pro annular boosters for every day driving. How about 950 or 1000 cfm with the annulars
Dr. Detroit
Received 3,892 Likes
Annular vs. Downleg has zero to do with vacuum at WOT if the carbs for both types are properly sized for the application.
Generally I have watched most annular stuff go pig fat past the power peak because vacuum will return......but this is going off track.
.5 is the number......WOT.
Jebby
Jebby
Street Rat (03-23-2018)
Jebby
Jebby
Dr. Detroit
I would love love to try a 1000 cfm dominator for the heck of it. Likely much to big for street use.
I'm not a fan of secondary metering blocks with a power valve
You have a 700 hp small block........a 1000 cfm is not too big for it. A dominator can be tuned for the street, but a 1000 cfm 4150 carb would work very well. I have a ProSystems 1000 on mine and it works very well. Correct tuning is all you need.
