Alternator ground on 68
Old Mar 14, 2018 | 02:21 PM
Kyzarsoza's Avatar
Kyzarsoza
Default Alternator ground on 68
I installed new letric limited wiring harness is my 68. There is a ring terminal for alternator ground. My alternator is internally regulated, so I purchased and installed the conversion kit from lectric as well. Where should I attach the ground wire from the harness to the alternator? My alternator only has a positive terminal on the back.
Old Mar 14, 2018 | 06:05 PM
mikem350's Avatar
mikem350
If there is no screw hole on the back, ground it to anything convenient. OEM alternators have a screw hole.
Old Mar 14, 2018 | 07:39 PM
Sayfoo's Avatar
Sayfoo
Depending on the size of the ring terminal, you could use one of the long bolts that hold the alternator together.
Old Mar 14, 2018 | 11:50 PM
lionelhutz's Avatar
lionelhutz
It has to hook to the frame or engine. The wire is the ground for the front lights. The alternator was a convenient place to put it by running it with the other wires and connecting it to the spare threaded hole in the back.
Old Mar 15, 2018 | 01:02 PM
Kyzarsoza's Avatar
Kyzarsoza
Thanks, I'll mount to housing and see how it goes
Old Mar 15, 2018 | 09:53 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
You should be fine. I have a new internal regulated 100 amp alternator and there was a ground screw right on the top. I just screwed the ground terminal from my new LL harness to it and it works fine. Mines a 68 also
Old Mar 17, 2018 | 09:24 PM
buns's Avatar
buns
I'll wager that you have a threaded hole on your alternator for the ground, you're just not seeing it. On my Powermaster alt. it is at six o'clock as shown in the picture below. I used a stud since a bolt was hard to get in that tight spot. And it was metric thread, M8 x 1.25.
To Alternator ground on 68
