TH350 Driven Gear Seal?
Old Oct 15, 2002 | 11:06 AM
CHEESERAL's Avatar
CHEESERAL
Default TH350 Driven Gear Seal?
I've replaced the Driven gear assembly and o-ring seal and my trans isn't leaking from around the assembly but it is still leaking from where the cable is attached. is there a seal that goes in that assembly before the driven gear? If so does anybody know what size it is and where I can get one?
Old Oct 15, 2002 | 03:24 PM
jerryp58's Avatar
jerryp58
Default Re: TH350 Driven Gear Seal? (CHEESERAL)
There is another seal, but heck if I can remember exactly where it goes or what it's called.
Basically, it's a circular seal that is a U shape rather than an O. That doesn't sound too clear :crazy: I'll try to locate a pic, but I know others here have pictures of it.
You can get it at your local Chevy dealer.
Old Oct 15, 2002 | 03:27 PM
CHEESERAL's Avatar
CHEESERAL
Default Re: TH350 Driven Gear Seal? (jerryp58)
Thanks for the info, I'll call a dealer and see If I can get one.
Old Oct 15, 2002 | 08:15 PM
C3 Shark Tank's Avatar
C3 Shark Tank
That's an easy fix you can do yourself, if you have a good tranny shop around they'll probably give you a seal as it's more hassle to fill out a receipt for one. Here's a little more info Speedo Gear Change
Old Oct 16, 2002 | 11:01 AM
CHEESERAL's Avatar
CHEESERAL
Default Re: TH350 Driven Gear Seal? (C3 Shark Tank)
Thanks, I've already replaced the adapter, driven gear, o-ring, but I didn't get a seal with the new adapter. Went to the Chevy dealer last night, they had it all, driven gear seal, o-ring seal, 3.27 for both, I gotta remember, call the dealer 1st. One more time, I'll get this leak fixed.
To TH350 Driven Gear Seal?
