Help Needed, Pics Inside - Wheel Issue
Im kind of newbie here and I must say Ive learned alot already.
I hope someone could help me with my problem.
Im willing to change this plate but I cant find this on-line in order to buy it. It got some rust on it.
Can some please tell me what I should look over to ? under what name... English is not my native language so Im guessing Im missing something...
My Vette is C3 79.
A Big THANKS in advance!
Welcome to the forum! Where are you located?
Are you considering replacing the "spindle"? This is the part with the five wheel studs sticking out. I can see no reason to replace the one in your picture unless it is bent. A little surface rust is very common on this part. Go to eBay and type in 1979 Corvette rear spindle. You can find this part there usually for between $100 and $150 US. Please feel free to share more information.
Good Luck, Greg
Good Luck, Greg
The spindle
as you said is not bent. It just have some rust so I thought I should change it in order not to get in trouble. if you dont see its a problem than I feel a bit quiter now...I think Ill have some more questions very soon, just started a restoration project of that C3 beauty
(Love IT)
That spindle looks very good unless there is some damage I cannot see. Most of the spindles I have seen after pulling the rotor have more rust than this. I little work with a wire wheel and some steel wool and that will look like new.
Thanks you Guys!!!
Moving to another issue
