Wheel bearings
1) Knocker tool or spindle press... The knocker tool has a huge success rate, but when the bearings are froze to spindle you'll need the bearing press. When they are froze, you load the press... and if it sticks you smack the spindle with a hammer which will in most cases free the bearing.
2) Bench press and a bearing splitter. This will remove the inner bearing from the spindle. Do not attempt to press the spindle out on a bench press, you'll damage the caliper mounting bracket.
3) pre-alignment tool... This is used for setting up the clearance on the bearings before you install. We try to set them between 3 and 4 thousandths.
4) Magnetic dial indicator for checking the bearing clearance. We don't use magnetic here because we have fabricated an indicator that will mount to the caliper mounting bracket.. it's a bit more accurate... but for home use the magnetic will do just fine.
5) Bearing puller tool.. once you have the clearance set up, then you use this tool to pull all the items together..
Hope this answers your questions and if you need links to the tools they are on our site, I'd be happy to post them for you. (and you can use the coupon codes on them)
Willcox
One note I'll add.. is that you wouldn't believe how many trailing arms we receive where the customer took it to a shop and they tried to press the spindle out of the arm from the caliper mounting bracket.... We get these arms in with broken brackets and/or bent brackets. The caliper mounting bracket is not something that can handle the pressure required to remove the spindle, but in-experienced shops won't know this.
Willcox..
1- Tools- basic hand tools, 0-1" GOOD Quality indicator and mag base, Bearing setup tool or old axle can be modified to work, press 12-20 ton HF imported will work.
2 - Parts- Nothing special about these bearings- any bearing house can get them - use Timkens over cheaper ones. Any vendor will have the parts, quality varies on such parts as the front bushings, SS parking brakes, seals. Go cheap and you will do them again.
3- Machine access, while access to a surface grinder isn't 100% needed it's the best way to dial in the shims. Everyone throws out the 002 endplay spec and has for years, even those who have never rebuilt a TA will tell you that. In reality that 002 endplay on a setup tool can open to 006 in final if the shim setup is not correct.
4- Just about every arm I take apart can I use nothing but the knocker tool and 4 lb or 5 lb mini sledge. You will need to remove the outer bearing with a bearing splitter or by carefully cutting it off. I have the special splitter made for them but those around the world used what they had access to.
5- Lastly- patience and knowledge. I can supply the knowledge, do you have the patience to do the job correctly?
If you can meet the above I can teach you to build them and they will be very well built.
I have taken apart 30-40 year old arms out of one owner cars that appeared new. There was no bearing play, roughness or noise. The arms were prestine, no rust at all, and once they were apart there was no grease left on the bearings. Two such builds come to mind and were stored inside since new with little miles on them. If the new owners didn't go through them they would have overheated and locked up for sure. So mileage isn't always a factor. Another one from CA was also perfect appearing but the car was left on grass a couple of years, the bearing rollers were rust seized to the race, even with grease around them.
I am here to offer tech advice , teach, and answer questions if I can. I am on many corvette online forums on the WWW and get contacted from all avenues BUT I do not solicite work from this site. In respect to your arms if you have questions I would be glad to offer you any advice I can to help you. You can post them here or contact me directly. Any rebuilder can replace the bearings, the process and parts are the same for GW arms- they use the same bearing supports.
