Q-jet is leaking
Old Oct 15, 2002 | 03:36 PM
HEARTBEATUSA's Avatar
HEARTBEATUSA
Default Q-jet is leaking (how do I I.D. it)
O.K. fuel is wicking out of top of carb and top gasket,
A:rebuild it? is this a reasonably succesful endeavor?
B:replace it? with what?
I have more time than money this week, so I'm leaning at rebuilding it, where do I locate the P/N on the carb.
let me know what you guys think
Thanks again
[Modified by HEARTBEATUSA, 3:39 PM 10/15/2002]
Old Oct 15, 2002 | 03:47 PM
R. Bruno's Avatar
R. Bruno
Default Re: Q-jet is leaking (HEARTBEATUSA)
Mine was doing the same thing - sort of weeping all over. I had never rebuilt one before and it was not difficult. I did not get into rejetting and other technical modifications which I am sure takes much more skill. Take your time and stay organized. The parts were approx. $40 (I put in a new float -$12, which did not come with the kit.) I can't recall where the carb number is, I think on the drivers side or back of the carb stamped vertically but someone here can supply you with that info. I vote to rebuild. Good luck :cheers:
Old Oct 15, 2002 | 05:02 PM
HEARTBEATUSA
Default Re: Q-jet is leaking (R. Bruno)
I just need to know where to find P/N there's a few different stamped on the body but which is which?
Old Oct 15, 2002 | 05:07 PM
Shark Racer's Avatar
Shark Racer
Pretty sure it's right there. It may be hard to read. Wipe down with some sort of cleaner if so. (I used simple green)
-Steve
Old Oct 15, 2002 | 05:29 PM
The_Dude's Avatar
The_Dude
St. Jude Donor '11, '16-'17
I took my carb with me to NAPA so that they could match up the number with the correct kit.
Old Oct 15, 2002 | 05:33 PM
Shark Racer
Default Re: Q-jet is leaking (The_Dude)
Yep. All you need is to get that number, though. Should start with a 70 or 170. (Probably 170.)
-Steve
Old Oct 15, 2002 | 05:40 PM
HEARTBEATUSA
Default Re: Q-jet is leaking (Pacin'California)
I got it, thanks :cheers:
To Q-jet is leaking
