350 top end upgrade question
Old Mar 24, 2018 | 07:07 AM
pb4's Avatar
pb4
Default 350 top end upgrade question
I have a 350 from a 1973 Z28 setup with
- 3972116 intake (1970 LT-1 replacement part)
- camel hump heads (186)
- Hooker headers into 4" side pipes
- Edelbrock carb
Now I have the opportunity to get a set of :
- Performer RPM intake
- Edelbrock 6089 heads
I'm looking to get a bit more hp in the low RPM range as I don't really drive >3000
Would you do it ?
Old Mar 24, 2018 | 08:24 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Not if I never rev it up over 3K. Its a waste of money. If you want more low end tq for your driving style, consider an rv cam.
Old Mar 24, 2018 | 09:05 AM
pb4's Avatar
pb4
has some kind of cam in it already, doesn't seem like a monster but has a bit of loopadyloop, could do with more I'm sure
Old Mar 24, 2018 | 09:11 AM
drwet's Avatar
drwet
If you can hear the cam at idle, you probably don't need more cam. The Edelbrock RPM intake and heads will certainly be an improvement over what you have. I agree that most of the improvement will be over 3000 rpm, but who doesn't run their Corvette over 3000 rpm? When making power its all about matching parts. It would be very helpful to know what cam you have so you can decide if its an appropriate cam for what you want the engine to do, and what parts are appropriate to go with it.
Old Mar 24, 2018 | 10:45 AM
Dynra Rockets's Avatar
Dynra Rockets
If staying under 3000 rpm then CR is your friend. Use 58cc heads.
Consider trans swap with a steeper 1st gear ratio (T5 or TH350 or 700R) to maximize acceleration with the power you already have.
Old Mar 24, 2018 | 10:53 AM
63split63's Avatar
63split63
Default Probably Best Left Alone
If your engine runs good . has good compression and oil pressure and does not burn oil you would be better off to leave it alone .
Trying to attain specific performance goals doing a partial rebuild is a waste of time and money .
Old Mar 24, 2018 | 11:16 AM
MelWff's Avatar
MelWff
Nothing wrong with what you have. If you want better low rpm acceleration change the rear end gears.
Old Mar 24, 2018 | 11:25 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
What else do you know about the current setup? What is the compression ratio? Do you know what camshaft is in it now? Has it ever been rebuilt? Parts in the engine really need to compliment each other. Lots of folks mix and match parts without consideration of this. What you end up with then is a none optimized combo that is lacking in performance. I would consider an all around build to meat the goals you want.
Old Mar 24, 2018 | 12:45 PM
pb4's Avatar
pb4
thanks guys, good advice, I'm leaning towards keeping it as it is.
I know nothing else about the engine other than what's been posted above.
I've always had a itching for a 5 speed swap, maybe that's the way to go.. have a 3.08 diff with a Muncie..
Old Mar 24, 2018 | 01:09 PM
Dynra Rockets
The 3.08 is the reason for the lack of grunt. Swap to a 3.36 or steeper. 5-speed along wth the steeper rear gears is very nice combo.
I have a base '69 300hp 350 with 58cc L98 heads for a ~11:1 CR along with a T5 and 3.36 rear. I won't win any drag races but feels great around town!
Old Mar 24, 2018 | 01:34 PM
zrc3john's Avatar
zrc3john
Banned Scam/Spammer
Again, if you have 3:08 rear there is absolutely no need for a 5 speed....Unless you were going for a 3:55 or 3:70....
Old Mar 24, 2018 | 02:07 PM
drwet's Avatar
drwet
3.73 gears and a TKO 500 or 600 would wake it up quite a bit, and give you better mileage. But to answer your question, yes I would do the heads and the intake if you're getting a good price on them, but I wouldn't be planning to stop there
Old Mar 24, 2018 | 02:15 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
wanting more power, hmmm is that a thing?
sounds like you are making a good decision about
waiting.
make a plan, get a true idea of cost and time.
then the need to upgrade the things more power
has a way of over stressing.
glad it runs good now.
Old Mar 24, 2018 | 02:52 PM
zrc3john's Avatar
zrc3john
Banned Scam/Spammer
A 383 would give it a lot more acceleration...😎
Old Mar 24, 2018 | 07:03 PM
drwet's Avatar
drwet
Just replaced my 383 with a 427. Take my advice...go straight to the 427.
Old Mar 24, 2018 | 07:06 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
good advice,
Old Mar 24, 2018 | 08:39 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Install the heads and leave everything else alone......that is what I would do......the LT-1 intake is a surprising piece......it will work well with those heads. If the heads are really 186 casting....then the 64cc Edelbrocks will bump the compression a point.....this will see a benefit everywhere in the curve......hell, the Edelbrocks flow so much better that you would see an increase everywhere anyway.....plus shave 50 lbs. off the front of your car. Pay attention to pushrod length and use only hardened black oxide pieces......go with some Harland Sharp rollers....if you trim the drippers off of the stock valve covers they will fit.
This engine would make an easy 400-410 horsepower and run like gangbusters....
I say do it. But keep the vintage intake for sneaky looks.
Jebby
To 350 top end upgrade question
Old Mar 25, 2018 | 02:31 AM
minitech's Avatar
minitech
Replace the gears only. 3.73 to 4.10 That is the single most noticeable change that can be made.
Discreet engine mods will essentially have you claim great improvement proportionate to the money you spent. Rear end gears will have you or anyone else that drives the car smiling with OBVIOUS large improvement in pick up and seat of the pants improvement in acceleration.
You know that lull or bog in pickup at 1200 or so rpm, everyone will admit that or lie. The rear gears fix that with your power coming in higher than that and a nice clear feeling (true feeling) of faster acceleration.
Old Mar 25, 2018 | 07:59 AM
cooper9811's Avatar
cooper9811
Just a thought- if you are looking for a cheap improvement in the "seat-of-the-pants" feel, what is your timing set at? Engine is not stock so decent chance this is already done, but a performance timing curve may also net some improvement, and it's the cheapest mod that you can feel.
Here is an older post with a lot of good information:
https://www.corvetteforum.com/forums...long-post.html
I would go through this before spending any money on heads/intake/etc. But otherwise, I also agree with Jebbysan if you go ahead with the heads. The timing info is almost universally applicable anyway.
Old Mar 25, 2018 | 11:07 AM
zrc3john's Avatar
zrc3john
Banned Scam/Spammer
4:10 rear with a 4 speed? I cry on the highway with my 3:70 rear 4 speed....Now, if your only light to light,than I'm like, OK....
