getting the struts off - is there a trick
Old 03-25-2018, 07:08 PM
vince vette 2
vince vette 2's Avatar
Default getting the struts off - is there a trick
Struts are detached from the strut bracket (which is a good thing as it is sitting in a box). The nut holding the strut to the spindle arm is off. The nuts on the top and bottom eyes of the shocks are loosened. Per the book I should be able to push the L shaped arm that holds the strut and bottom shock eye out. But they are rather immobile to say the least. Granted, they haven't been removed since they were put in in 1980. But before I get a bigger hammer (literally) I just wanted to be sure I wasn't missing something.
Old 03-25-2018, 07:30 PM
calwldlife
calwldlife's Avatar
St. Jude Donor '22
where the shock mounts?
tap it up and down and up to then center@ so it can come out.
Old 03-25-2018, 07:49 PM
Big2Bird
Big2Bird's Avatar
Received 1,014 Likes on 808 Posts
They make a "knock off tool" for that.
Old 03-25-2018, 08:37 PM
mikep3
mikep3's Avatar
Knock off tool, power blaster and one beer, job done.
Old 03-25-2018, 08:41 PM
vince vette 2
Originally Posted by mikep3
822
Got the power blaster (been spraying it for weeks), got the beer (been drinking it for years), the tool with have to be jerry rigged (however that's spelled).
Old 03-25-2018, 08:42 PM
vince vette 2
tomorrow's attempt - I'll let you know.
Old 03-25-2018, 08:45 PM
calwldlife
calwldlife's Avatar
St. Jude Donor '22
there is a flat that gets turned against because of shocks.
so tap at shock mount area to twist the thing in the hole.
back and forth.
should loosen
vince vette 2 (03-25-2018)
Old 03-25-2018, 09:25 PM
vince vette 2
back and forth.
should loosen
I see what. That makes sense. Thanks
Old 03-25-2018, 09:41 PM
'75
'75's Avatar
Some here have used a 3/8 pipe cap for a knock out tool. Just be careful to not break of one of the ears on the bearing support.
Old 03-25-2018, 11:51 PM
Big2Bird
Big2Bird's Avatar
https://willcoxcorvette.com/corvette...out-tool-63-82
The funny thing is, I have a rear hub/axle tool for my Model T Ford.
It's identical. Some things never change.
Old 03-26-2018, 12:53 AM
70Yellowbird
70Yellowbird's Avatar
Please take a look at this photo of a removed part ... and be careful what you twist. You will need to move it straight back w/o twisting until you clear the small spline.
back and forth.
should loosen
Old 03-26-2018, 07:02 AM
calwldlife
calwldlife's Avatar
St. Jude Donor '22
Old 03-26-2018, 07:21 AM
vince vette 2
Gotta go with what works. In high school some of my friends were working at a plant making front axle assemblies for Ford. The king pins would fit right into the the 32 Roadster my father had given to my brother and me. I'd post pictures but they don't want to take.
Old 03-26-2018, 07:22 AM
vince vette 2
very helpful. thanks,
Old 03-26-2018, 09:50 AM
MelWff
MelWff's Avatar
Received 1,820 Likes on 1,609 Posts
you never stated why you are trying to remove them, from other posts you mentioned changing shocks but those dont have to be removed to change the shocks
Old 03-26-2018, 12:00 PM
vince vette 2
Strut bushings appear a little rough after 38 years and 90k miles
Old 03-26-2018, 12:02 PM
MelWff
MelWff's Avatar
wow!
To getting the struts off - is there a trick
Old 03-26-2018, 12:06 PM
vince vette 2
Back to the some things never change - same king pins in this '32 Ford roadster as what Ford was putting into some new vehicles well into the 70's if not 80's
As it has sat since before I got my '80 vette new
It's worth more like this than my vette will be worth at a reasonable level of rebuild
Old 03-26-2018, 12:18 PM
vince vette 2
wow!
Something tells me it wasn't the differential causing all the noise I was hearing back there despite the fact that both clips on one of the clutch packs were broken and the gears had to chew them up along with a plastic tip someone (not me) left in there from a gear oil bottle.
Old 03-26-2018, 12:20 PM
jim-81
jim-81's Avatar
Heat, hammer, torch, air chisel, .. and beating the f*** out of it!
Quick Reply: getting the struts off - is there a trick
