brake light issue
Old Mar 26, 2018 | 04:12 PM
michaelroy's Avatar
michaelroy
Default brake light issue
I have searched previous threads but didn't see anything that addressed my problem. I have a 79 Vette. Both brake lights Work. Both tail lights work. However, when I push the brake pedal with the tail lights lit the driver side brake light goes out. New bulb, cleaned socket. The brake light switch is maybe a month old.
Any suggestions where I can start my search?
Old Mar 26, 2018 | 11:07 PM
speedreed8's Avatar
speedreed8
Sure you have the correct style bulb in that socket.
Old Mar 27, 2018 | 12:49 AM
Greg's Avatar
Greg
Just another Corvette guy
MR,
You have a bad ground on the driver's side tail light.
Look up under the back side light mounts. Each socket will have a ground wire attached to the mounting nut. The driver's socket ground is either corroded or missing. This is a very easy fix.
Greg
Old Mar 27, 2018 | 12:14 PM
michaelroy's Avatar
michaelroy
Thank you gents for the help. After fooling with the thing for a while I have determined the socket is bad. The pos+ side in the socket contact goes down past where the bulb contacts it. Got a new one on the way.
To brake light issue
