Building my Dream Car - 1968 Corvette
#181
Brake Update:
I put on the vacuum booster and it was better but not great. They work, but you have to get FAR into the pedal for them to go. I KNOW there is no air in the system. (I bled them, a mechanic I trust bled them, I think God himself even bled them). I called and talked to Wilwood AGAIN and the guy said (seems more knowledgeable than the last guy I talked to) that the 1" bore Master Cyl they told me to go with before will NOT move enough fluid for those brakes.
So now my plan is to buy the 1 1/8" bore, take out the pump AND the booster, rebuild the front and middle brake lines and convert to manual.
Thoughts?
Thoughts?
#182
Brake Update:
Thoughts?
Thoughts?
#183
caskiguy (01-31-2019)
#188
Update:
Brakes - After fighting the brake booster for a long time, I violently pulled it and the vacuum pump out of the car. I moved the master cylinder plunger rod up to the upper hole on the brake pedal and raised the MC when installing it onto the firewall. I now have manual brakes. They work so much better. Yes it does take more force to stop, but they work like they are supposed to now. Much happier.
Steering - I put in the Steeroids Rack and Pinion. Super easy to install. No cutting or welding. It fit fine with my Hedman headers (thank goodness). It was a bit of a challenge doing it alone but I managed it. I also put in 3 shims into my power steering pump to reduce the pressure to 850psi so the steering was not over assisted. It is so much better now! I love it.
I highly recommend the steering!!!!
#189
Update:
#190
Here is the power steering kit I used. It has good instructions with it. I didn't take any pictures. sorry.
Basically you take the nut from the high pressure line attachment off, use a magnet to pull the valve out, unscrew the end, add 2 shims, and then put it back together. SO much better.
#191
Wow what an awesome build! Your 68 looks fantastic! I hope my 68 looks that good one day lol
scottjamison (05-19-2019)
#192
These are the headers I went with: https://www.summitracing.com/parts/hed-68093
Here is the power steering kit I used. It has good instructions with it. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
#193
Stay with the orange red. It’s beautiful. Too many red vettes out there. Great thread. Great car. One word, hydro boost, one of my top three mods.
scottjamison (05-21-2019)
#194
#196
Since the thread on it was 11 years old, is there a best place to get the system from?
I found this place. Looks like a very complete kit.
http://www.hydratechbraking.com/C3Corvette.html
#197
St. Jude Donor '12-'13, '15- '16-'17-'18-'19, '21
Thanks for the idea on Hydraboost. I had not looked into that but I want to now.
Notice that the one showed is for 1977-82. And another for the 1968-76.
Do a search here in forum and you will find many DIY versions.
DurangoBoy is not on here anymore but may be over on Digital Corvette.
I picked up 2 units complete except for the custom lines which I'll do for my setup once I am ready.
Got one from Matt (DB) and one from another member.
Installation instructions are saved somewhere on my computer if you want them.
Go for it....
#198
#199
Over the weekend I had a big project. I still wasn't happy with the feel of the suspension, so I decided to put on tubular control arms. I went with the Global West arms after talking to the company and doing some research on different options.
I had a list of items I wanted to do while I had things torn apart, so I took a three day weekend and did it.
Some things of note when going to tubular control arms (I think most of them are fairly similar in these ways):
1. Most of them have a big assed nut on the ends of the shaft that bolts it to the frame. The upper will interfere with your electric fan shroud depending on what you have. I had to pull the radiator and notch the shroud. The lower may hit your front sway bar. Keep an eye out.
2. It will probably change your ride height. For me this was no big issue since I have adjustable Viking shocks. But if I still had the stock setup I would be ordering new coil springs. Mine sits > 1 inch lower.
3. You don't have to completely remove your calipers. Just take them off and hang them with a zip tie with a block between the pads.
Here is a picture of the old and new side by side.
While I was under the car, I had ordered new bushings for the rear strut rods because I realized I had forgotten to do those originally.
Here is the old and new. I guess the old ones were pretty warn.
Finally, the stance with the new control arms. I'm very happy.
Final word on the changes is "OH MY GOD WHAT A DIFFERENCE!!!"
It is so much smoother. The steering finally feels like I wanted it to and it sucks up the roadway way better now. I wish I had done this originally.
Now to go get an alignment............................
