73 Big Block Water Pump?
Old Mar 30, 2018 | 07:27 PM
OldCarBum's Avatar
OldCarBum
Default 73 Big Block Water Pump?
On goes the collection of parts for my 496 build.
I'm looking at water pumps and plan to go with a good mechanical and want to use all my stock brackets and pulleys.
I'll be using dual spal electric fans on a Dewitts radiator.
Do I gain anything going to a high volume pump?
I see several different shaft sizes offered.
Do I need a long or short style?
I assume aluminum is the way to go?
Old Mar 30, 2018 | 07:33 PM
Mooser's Avatar
Mooser
If you're using your original brackets and pulleys you'll need a short pump, 3/4 pilot.
Dual spals on a dewitts rad should cool everything, personally I went with a "regular" edelbrock aluminum pump (not hi volume or anything)
Oh, and a Corvette short pump may or may not be different length than a regular gm short pump.... depending on who you talk to. I had to add a little over .120" to a regular length pump to match my original pump and get the pulleys to align.
M
Old Mar 31, 2018 | 09:55 AM
derekderek's Avatar
derekderek
I THINK the 2 diff short pumps is a small block only thing...
Old Mar 31, 2018 | 10:29 AM
Mooser's Avatar
Mooser
(or at least I think I agree, all C3 BB vette = short pumps are supposed to be 5 3/4" with a 3/4" pilot)
And with the SB it wasn't much of a difference, 1/8" or something after 70?
I think the confusion / problem arises because you can press the flange onto the shaft to different placed (as it was in my BB pump)
M
From Edelbrock cataloge
1969-70 350 Corvettes. Short Pilot = 5/8" Block to Flange = 5-5/8"
1971-82 S/B Corvettes. Short Pilot = 3/4" Block to Flange = 5-13/16"
1969-70 B/B Corvettes Short Pilot = 5/8" Block to Flange = 5-3/4"
1971-74 B/B Corvettes. Short Pilot = 3/4" Block to Flange = 5-3/4"
Old Mar 31, 2018 | 11:17 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Stewart pumps are highly rated. Be sure to check them out.
To 73 Big Block Water Pump?
