Choke issues on cold start (i know sighhhhh)
We've tried things with the electric choke before, but i noticed something today.
For the past couple weeks it's been cold starting like a dream. It was over 55 degrees everytime also. My only issue was that it was taking FOREVER to idle down. Like 10 to 15 minutes. I'd give it a little gas and it just would drop down to normal idle (around 700 or so). I ended up adjusting the lil black circle on the side of the choke (the coil i believe) a tiny bit and that fixed it.
BUT today i went to start her and had my reservations because even though its 58 today, it's rather windy and feels like its in the 40s out there. This is when i like to act up. Usually. I tried starting and nothing. Cranking forever no matter how i tried giving it a pump or holding it half down during cranking. I even let it sit for a good 15 before trying again and more of the same.
I thought to myself "maybe i adjusted that coil a bit too far" and went to adjust and that's when i noticed my choke valve was wide open. Upon following the rod attached to the choke valve down the side i saw that it wasn't resting against the red limiter thing....sorry guys, i don't know all the terminology here. It's a Holley Carb btw. I thought "if that handing valve rod was pushed up and resting against that red thing, it'd be closed" and that's what would happen when i messed with it hands on.
I was wondering however why it wasn't being pushed up. Is there supposed to be a spring here??? Did it fall off??? IS THIS WHAT HAS BEEN WRONG THIS WHOLE TIME?
Well i found out later that there is in fact a spring controlling this rod, but it's internal. That surprised me because i thought the coil just slowing turned the red limiter arm up and slowly opened up the choke. But apparently there's two springs at work here? One doing what i mentioned before, and another keeping the choke valve rod pushed against that red limiter?
I tested this by taping the choke closed and cranking and WHATTTAAAYAKNOOOWWWWW. She starts. She got choked out right away and i could keep it running however. If i tried to jump out and take the tape off to open it up it'd die before i could get there.
Here's the kicker though. A few minutes later, whilst i was stomping around the garage in all my glory, boasting to the scrap wood and extension cords about my epiphany, i went back to check on the choke rod and low and behold its pushed tightly against that red limiter arm again. I can move it away and a spring (internally) pushes it back like it should.
WHAT. IS. THE. ISSUE.
Is the choke dying? Is there a certain part of spring that goes bad and causes these issues?
Please respond to my novel i just spent 15 minutes typing and i'll forever be grateful.
Happy Easter guys!
The list# of the Holley is on the front of the airhorn.
On a totally cold engine, on a almost 60 degree day, after you step on the gas pedal once the choke should completely close with just a small amount of resistance if you try to open it with your finger tip.
