speedo seal leaking
Old Apr 2, 2018 | 10:46 PM
geoology's Avatar
geoology
Default speedo seal leaking
My speedo seal was leaking so I replaced with https://www.summitracing.com/parts/cin-sn19 but its still leaking
what else could it be?
thanks
geo
Old Apr 2, 2018 | 11:02 PM
CanadaGrant's Avatar
CanadaGrant
Check the gear itself. The shaft on the plastic gear wears on the seal allowing fluid to pass even though you have a new inner seal in the housing. Just lay a straight edge along the shaft.
Old Apr 3, 2018 | 08:20 AM
Scrrem's Avatar
Scrrem
thanks
geo
Mine was doing the same thing even after I replaced the O-ring. I removed the O-ring, took some Teflon tape and a made a single wrap within the grooved area where the O-ring laid in. Re-installed the O-ring I have no more leak.
Rich
To speedo seal leaking
