Correct fuel pressure?
Old Oct 16, 2002 | 03:15 PM
Maurice's Avatar
Maurice
Default Correct fuel pressure?
I just hooked up my fuel pressure guage and am getting a whopping 4psi at idle and when the engine is revved, it drops to around 2-2.5 psi. HAHAHAHA, no wonder I am sucking at the track and at high rpms. Shouldn't it be around 7psi ? This is on my 502ci/502hp engine.
Thanks in advance
Old Oct 16, 2002 | 03:18 PM
Fevre's Avatar
Fevre
Default Re: Correct fuel pressure? (Maurice)
7 to 9 for street I believe is correct. If it drops when reving you might have a whole in the pump diaphram.
Old Oct 16, 2002 | 03:31 PM
Maurice's Avatar
Maurice
Default Re: Correct fuel pressure? (Fevre)
I figured the pump was bad. I already bought a new one that is a 140gph from Summit. Hope to have it installed before the weekend.
Old Oct 16, 2002 | 03:35 PM
Fevre's Avatar
Fevre
Does it need a pressure regulator and do you have one? I intalled what I thought was a Holley street pump but found out it was the strip pump in a street pump box and the pump has info on it. It over powered the shut off valve in the fuel bowls and flooded the engine at idle.
Old Oct 16, 2002 | 03:54 PM
Maurice's Avatar
Maurice
The one that I got requires a fuel pressure regulator and came with it. The install looks pretty simple, I just have to get out there and do it now. I need to pick up a fuel filter to replace the one I have now. My current fuel filter has a fuel return line connected to it, but isn't a fuel pressure regulator. I am still trying to figure out how to rework everything to make it correct.
Old Oct 16, 2002 | 04:51 PM
Marks69BB's Avatar
Marks69BB
I run 4 - 4.5psi all of the time with my 454. I tried it higher and was running way to rich with backfiring. This was confusing since my Demon 850 manual recommends 6 - 7psi for hipo engines. I've heard you should always run a regulator with an electric for constant consistant fuel delivery. :cheers:
Old Oct 18, 2002 | 04:28 AM
Maurice's Avatar
Maurice
Default Re: Correct fuel pressure? (Marks69BB)
Interesting... I was playing around with my fuel pressure today by blocking off the fuel return line and that bumped the pressure to around 6.5. I was having similar issues to what you were describing... plenty backfiring when acceleratiing, as soon as I put it back, it ran great. HMMMMMMM
Old Oct 18, 2002 | 04:37 PM
fireball's Avatar
fireball
The Holley book says anything over 8psi will force the floats open and cause flooding. I'm having similiar pressure drop issues (although not related to the return), so I'm interested in your results. Especially at the track.
Old Oct 21, 2002 | 06:47 AM
Maurice's Avatar
Maurice
I got everything installed today (regulator, new fuel pump, and filter). I set it for 4.5 psi and the difference is incredible at the higher rpms! I cannot wait to see how much diff I have in the 1/4 now that I can rev in the gears. The idle is now much smoother also for some reason. I was sitting at the stop light thinking how incredible it is that a 500hp engine can idle so smoothly. Technology rocks!
To Correct fuel pressure?
