Is the piston tool needed?
Old Apr 16, 2018 | 04:38 PM
Dusky's Avatar
Dusky
Default Is the piston tool needed?
Hi guys!
I've rebuilt a few calipers before, but never corvette c3 calipers.
i see there is a special tool for sale to rebuild the calipers on our cars.
https://www.ebay.com/itm/1965-82-Cor...-/380278729069
Is this needed? I am going to use original lip seals, No O rings. I've never seen a tool like this before on other calipers.
Any insights are welcome
Old Apr 16, 2018 | 05:08 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I've never used one and my brakes work just fine. Save your $$$.
Old Apr 16, 2018 | 06:27 PM
TimAT's Avatar
TimAT
The idea behind that tool is to make sure the seal lip stays pointed toward the back. Not really needed. IF the lip rolls as you install the piston, it will be hard to turn. Correctly installed, the new seals and pistons will rotate in the bore without much effort. Lube them all well with brake fluid.
Old Apr 17, 2018 | 10:34 PM
Indiancreek's Avatar
Indiancreek
Check the cylinder bores for wear or rust or pitting. I'd hone them them make up your mind. I always hone them anyway. There is a similar sleeve for your crank if the snoot has lip seal wear. or use an offset timing ci=over seal. I don't think anyone can give you absolute suggestions without seeing your calipers.
To Is the piston tool needed?
