Stomping it
Old Oct 16, 2002 | 08:01 PM
Bullyj's Avatar
Bullyj
Default Stomping it
When I stomp it I don't shift until 6500 rpm as I believe I have a stock engine this concerns me (don't want to blow motor) I changed the detent cable and adjusted it per manual and still no difference. I don't know if a shift kit has been installed or not. I also replaced the modulator valve any ideas how I can get the shift down to 5000 rpm. otherwise shifts perfectly
Old Oct 16, 2002 | 09:47 PM
RoyArms's Avatar
RoyArms
Default Re: Stomping it (Bullyj)
You prolly put an adjustable modulator in there, you just need to adjust it to whatever you want it to shift at. There is a screw in the part where the vac hose goes on, I think it is screw it in for lower shift point but not sure. It should have come with instructions.
Old Oct 16, 2002 | 10:04 PM
73 LS-4's Avatar
73 LS-4
Are you sure your tach is reading correctly? The reason I say this is that a stock L-48 will have fallen on it's face long before 6500rpm. I'd varify this before changing something that may be fine.
:cheers:
Pat Kunz
To Stomping it
