hard restart
Old Apr 16, 2018 | 07:41 PM
Ronnie D's Avatar
Ronnie D
Default hard restart
TimAt and calwildlife,triple checked fuel filter its in correct. and gas tank is clean as a hounds tooth. New fuel pump and new in line fuel filter the one with the return line to the gas tank. I truly appreciate the input so far guys.you guys are great to respond so fast. Ronnie D from New Haven, Conn
Old Apr 16, 2018 | 07:47 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
2 threads make it hard to keep info straight.
i would tap on top of fuel bowl with handle of screw driver to see if the carb
float and needle get stuck.
the squirters will show if gas is in the carb.
as long as sqirters are good.
