Vibration source probably the exhaust
Old Apr 18, 2018 | 03:42 PM
DorianC3's Avatar
DorianC3
Default Vibration source probably the exhaust
Hey All,
After driving around and feeling the floor, I think I may have found the source of the vibration: the exhaust pipes. Behind the central bracket, one side is clearly against the bottom of the vehicle and the other is not much better. There should clearly be much more clearance.
And I don't know about you but, I like my corvettes well hung
How is a 1969 manual's exhaust hung?
(H/T to the source); should the pipes be clamped straight to the hanger with no rubber insulation?
Old Apr 18, 2018 | 03:45 PM
MelWff's Avatar
MelWff
the rubber of the transmission mount is the insulator
Old Apr 18, 2018 | 03:47 PM
DorianC3's Avatar
DorianC3
I was kinda figuring that was how it was engineered - doesn't seem like a good idea.
Old Apr 18, 2018 | 03:52 PM
DorianC3's Avatar
DorianC3
And... the cherry on top is that I just figured out that replacing the worn trans mount probably compounded this. The old rubber was worn flat! Replacing the mount added at least 0.5 inch if not more. Enough to drive the pipes into the bottom of the vehicle. Tomorrow I'll see if I can fab up a spacer to lower it.
Old Apr 19, 2018 | 03:00 PM
DorianC3's Avatar
DorianC3
Yep. That solved it. Some prying and wrenching fixed the problem.
To Vibration source probably the exhaust
