1977 Corvette Steering Column Issue Upper Bearing Seat?
I have a 1977 Corvette with Tilt and Tele. I just finished rebuilding my steering column, including new upper bearing, lower bearing, turn signal switch, and other parts. Upon reassembly and reinstallation, I found my steering to be uncomfortably loose, as in there was play and I could jerk the wheel about 1/8 up, down, left, and right. After looking closely at Jim Sheas Steering Papers, I noticed I was missing a part. I must have lost this part during reassembly, or perhaps it never existed in my column. The part is the Upper Bearing Seat, GM# 7804909. I cannot seem to find this part anywhere. Any ideas if this is the part that will solve my issue? Any suggestions where to find it?
Thanks for the help!!
I would like to avoid buying the expensive kit to get a potentially inexpensive part. The part I need is the center retainer in the picture from Eckler's.
the link only goes to the Ecklers site not the part you want.
Sorry, the link is: https://www.ecklerscorvette.com/corv...1978-1982.html.
Ecklers Part Number: 25-239427-1
"Corvette Steering Column Spring Kit, Tilt, Upper, 1978-1982"
I called Eckler's asking if they could split up the kit so I may just receive the spring seat, but they said that was not possible. I also called a GM dealer just to make sure there was no way they could acquire it, and of course, they said it was discontinued and unavailable. I ended up ordering the $60 kit from Eckler's.
I hope this part solves my loose steering wheel issue!
Update:
I learned the hard way that the 1977 Corvette Steering Column does not use a upper column bearing seat. I discovered I was inserting the plastic bearing retainer backwards, causing slop in the steering after it was buttoned up.
All is good now!
All is good now!
