Need 82 help!!!!!!
Old Oct 17, 2002 | 01:09 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Need 82 help!!!!!!
I need to know what was the factory setup for holding the valance (front air dam(scoop)) up?
Mine has nothing to hold up the center of it. I have seen the bracket that is on the 80, is this what it is supposed to have???
I sure am getting tired of trying to tie or zip tie it up, and it is really getting scuffed up when it comes loose and drags the pavement :cry
I couldn't find any pics of it in the AIM to illustrate what I need...
Old Oct 17, 2002 | 01:50 AM
82dukman's Avatar
82dukman
Default Re: Need 82 help!!!!!! (Desertdawg)
Are you talking about the piece that the spoilers bolt to?
Old Oct 17, 2002 | 02:56 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Need 82 help!!!!!! (82dukman)
Waiting for an e-mail from 82 Dukman.... :cheers:
Anyone else have pics????
Old Oct 17, 2002 | 02:59 AM
82dukman's Avatar
82dukman
Dwayne, you will have it within two days as per our IM. I promise :cheers:
Old Oct 17, 2002 | 05:00 AM
Twin_Turbo's Avatar
Twin_Turbo
That would be the towing hook, mounted on the frame extension :)
[Modified by Twinnie, 3:39 AM 10/17/2002]
Old Oct 17, 2002 | 05:36 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Need 82 help!!!!!! (Twinnie)
I am looking for the center metal bracket that holds up the lower spoiler.
Old Oct 17, 2002 | 07:29 AM
Ybnormal's Avatar
Ybnormal
Desertdawg,
I was wondering the same thing. I'm in the process of replacing mine but can't figure the front mounting scheme. If you get any pictures please post.
YBNormal...drive a vette
Old Oct 17, 2002 | 09:01 AM
PB82CE's Avatar
PB82CE
Yep, I had the same problem. Mine was bent, and not connected to the
spoiler. Just had it fixed. My mechanic straightened it out, bolted it to the
spoiler, and no more scraping! :yesnod:
This is a very hard item to come across. You may want to try a Corvette
used parts vendor or salvage yard.
Old Oct 17, 2002 | 09:05 AM
PB82CE's Avatar
PB82CE
Dukman comes through once again!!! :cheers:
Old Oct 17, 2002 | 11:39 AM
TJKirby82CE's Avatar
TJKirby82CE
Default Re: Need 82 help!!!!!! (Peter Bilella)
I also had the same problem, must be very common. One word of advice, do not let your wife drive the car with out you in it, they will pull up so far the front spoiler will turn into a street sweeping device! :cheers:
Old Oct 17, 2002 | 12:25 PM
81VETTOM's Avatar
81VETTOM
Default Re: Need 82 help!!!!!! (TJKirby82CE)
my 81 and 82 are/were both bent. I would like to see a pic posted of the attachment, from the factory, just to be sure. I think the air dam is held up by the bracket...correct? Anyone got a pic they could post, I would appreciate it, at least I can get it close to what it should be. :smash: thanks
Old Oct 17, 2002 | 02:26 PM
82X-FireVette's Avatar
82X-FireVette
I had the same problem. I bought a repro frame extension and replaced the bent original. I guess the front tow hook is the first thing that hits a parking divider and then bends upward. I had to modify the repro because the air dam bracket was way too high. I got the spoiler correctly aligned after welding a new bracket even with the bottom of teh tow hook, similar to teh original design. It works great now. Gotta be careful when parking, though! I still have the original frame extension and am saving it for a spare part because it is repairable. I don't think the original version is made any more. :chevy
Old Oct 17, 2002 | 05:33 PM
Jim Martley2's Avatar
Jim Martley2
Here are 3 pictures I just took of my 82. The bracket was originally bent REAL bad. I cut it off , straightened & reinforced it. I also made it a "bolt on" arraingment, just in case of a lapse in distance judgment :) :)
Old Oct 17, 2002 | 06:39 PM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Need 82 help!!!!!! (Jim Martley2)
Hey Jim, that is what I am looking for...( I know no-one will have a spare lying around) so your pics will help me a bunch in trying to make one :cheers:
Do you have any other pics, or some dimensions that I could go by :confused:
Old Oct 18, 2002 | 07:27 AM
Jim Martley2
I don't have any other pictures right now but if there are any others you need, just tell me what angles you would like & I can take more.
Old Oct 18, 2002 | 07:50 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Ok Jim...i am waiting to see what Dukman emails me.....
Old Oct 18, 2002 | 07:56 AM
Ybnormal's Avatar
Ybnormal
Jim,
Thanks, you the man :cheers: exactly what I was looking for. I had no idea how it was originally mine is so mangled. What a great idea to make it a bolt on. I'm going to be doing the same to mine. Thanks again!
To Need 82 help!!!!!!
