Alum heads
Old Apr 25, 2018 | 05:28 PM
super charged's Avatar
super charged
Default Alum heads
In my quest to to shave some pounds I added these to the mix, be cutting on the flywheel also.
Old Apr 26, 2018 | 08:33 AM
DaGuvner's Avatar
DaGuvner
When I built my 383 stroker I replaced the cast iron oem intake, heads, and water pump with aluminum pieces also replaced the cast exhaust manifolds with long tube headers.
While doing this I weighed each of the old components and new. The total weight differential was almost 100 lbs. I was amazed.
I also replaced the stock rear leaf spring with a VB&P composite. Did not weigh those pieces but would guess old multi leaf steel spring around 70 lbs. Composite spring 3 lbs.
Old Apr 26, 2018 | 07:53 PM
JoeMinnesota's Avatar
JoeMinnesota
Nice weight savings on the front end with aluminum heads and intake. The savings at the rear when going to a composite spring is between 30 and 35 lbs.
Old Apr 26, 2018 | 08:44 PM
super charged
Add to the mix Alum trailing arms hub and brake caliper brackets,
alum half shafts,hollow light weight axles, c6 wheels and wilwood calipers. Bat wing And more.
Old Apr 27, 2018 | 01:38 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Years ago I was told that reducing a (performance) car's weight by 100 pounds is equal to increasing the power by 10 h.p./it's technically freeing up the horsepower the engine already has.
100- 200-300 pounds in weight reduction really pays off.
That's a pretty good deal when going with lightweight performance parts/an extra bonus.
Old Apr 28, 2018 | 03:14 PM
Priya's Avatar
Priya
I vaguely recall that every 100 lbs saved in weight cuts .1 seconds off quarter mile time, but don't quote me on that.
Old Apr 28, 2018 | 10:25 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Let us know what the car weight ends up at. I always enjoy weight reduction threads.
To Alum heads
