C3 1978 Power door locks
Old Apr 27, 2018 | 09:36 PM
Brinella's Avatar
Brinella
8th Gear
Default C3 1978 Power door locks
My 78 has new power door lock actuators. If the doors are unlocked, the drivers side lock switch will lock BOTH doors. But that is all that works. The drivers side switch will not unlock either door, and the passenger side switch does nothing. Thoughts? Do I need to replace the wiring harnesses and switches on both sides? I’ve unplugged all the connections and cleaned the pins and connections with a wire brush. Appreciate any others suggestions.
Old Apr 28, 2018 | 05:04 AM
hunt4cleanair's Avatar
hunt4cleanair
I would suspect the switches, especially knowing the driver's side will activate the plungers and both doors will lock. I would replace those before replacing the wiring harness. After checking a switch on the Pace Car with ohm meter, I replaced it when it failed to continuity test.
If you have replaced the actuators, then you know how to access the lock gear behind the door panel. Check the article out with link below. It shows what to look for when examining the door switch like frayed wires.
Hope this helps!
Power Door Lock Repair
Old Apr 2, 2019 | 12:10 PM
rio9760's Avatar
rio9760
Default Power door locks 79 c3
how do the power locks actually work on the 79 C3? Since my locks never worked and l did not know l had power locks until l went to replace lock for new key? Thanks...
Old Apr 2, 2019 | 12:53 PM
pltmgr's Avatar
pltmgr
I have a very original 82 CE with only 11k on it. The previous owner spent a lot of time and some money attempting to get the power locks to work without success. I spent a lot of time as well. I finally discovered a disconectedted wire connector way up under the drivers side dash. I had to remove an AC duct to reconnect it. I have no idea why it was disconnected but reconnecting it solved my problem.
Are you certain all the connectors are connected?
Old Apr 2, 2019 | 01:00 PM
wajulia's Avatar
wajulia
Look at the wilcox explanation. The door lock circuit is quite complex, it does not work the way that logic would infer. If either of the switches is not working, neither will work properly.
http://repairs.willcoxcorvette.com/1...atic-and-info/
Old Apr 2, 2019 | 04:58 PM
hunt4cleanair
To the previous OP, power door locks are not really that complicated, but you must understand you are working with different technologies to make them work. You have the traditional mechanical linkage (that must be clean and freely moving), electro-magnetic actuators and then the basic electrical feeds.
Originally Posted by pltmgr
I have a very original 82 CE with only 11k on it. The previous owner spent a lot of time and some money attempting to get the power locks to work without success. I spent a lot of time as well. I finally discovered a discontented wire connector way up under the driver's side dash. I had to remove an AC duct to reconnect it. I have no idea why it was disconnected but reconnecting it solved my problem.
And as you illustrate, it can be as simple as a single wire disconnect. I found when troubleshooting my 78 power door locks, actuators that had gummed up from moisture exposure, the rubber caps had disintegrated, linkage was constipated from gunk and switch wires had become frayed. Perform some careful inspection and troubleshooting and you'll find your way to the clean air of power door lock functionality. LOL
Old Apr 8, 2019 | 04:25 PM
rio9760's Avatar
rio9760
I appriciat the time and info on the opperation of the door locks. I believe the locking pull tab works an actuator and this locks and unlocks both doors from inside only. I will get on the trouble shooting in my doors where there is no wiggle room to move or work. Thanks again guys >>>>>>>>>>>>>
Old Apr 9, 2019 | 04:57 AM
hunt4cleanair
When the switch is activated, electrical current is directed to the actuator. The electrical activates or moves a plunger in the electro-mechanical actuator and its the plunger that moves the linkage to either lock or unlock the door..
Old Apr 9, 2019 | 03:11 PM
DB Cooper's Avatar
DB Cooper
My 78 came with dead power locks and bad switches. Rather than go to the expense of replacing the switches and plugs (mine had wires falling off), I just picked up a remote keyless entry amd a couple ice cube relays. Cheaper and more useful too.
Old Apr 9, 2019 | 03:13 PM
DB Cooper's Avatar
DB Cooper
The key cylinder? You aren't mistaking the factory alarm switch on the driver side lock cylinder for a lock actuator, are you?
Old Apr 11, 2019 | 10:40 PM
Picasso451's Avatar
Picasso451
The ones in my '79 didn't work when I got it, found the ground wire on the passenger side door mounted to a painted surface for one, and both connectors at each switch had minor oxidization.
PLUS the contacts inside the connectors were stretched and not touching the pins. I managed to get behind them with a small nail and bend them back tighter, then they worked. Finally.
Old Sep 19, 2019 | 10:13 PM
rio9760's Avatar
rio9760
Hi l opened my door panels to replace my power door locks in my 79 c3 and low n behold l only have power to the drivers side? The pass side is manual, is this normal?
[/QUOTE]
Old Sep 20, 2019 | 03:47 AM
hunt4cleanair
No...not normal. Power from the fuse is directed to both switches, however, the passenger side actuator is activated from the driver's side. If you have a passenger side switch...is should be functional...not cosmetic!
Is this what you're asking?
You dropped the HTML quote characters for this second part which is confusing whether your questions continued or this quote (from initial OP) was just dangling.
Old Sep 20, 2019 | 10:12 AM
rio9760's Avatar
rio9760
No power meaning there is no wiring or electric actuator on my passenger door is this normal? Perhapes its just a power lock cylinder from the auto locking alarm system?
Old Sep 20, 2019 | 11:55 AM
rio9760's Avatar
rio9760
Default C3 79 door locks
Yes the wiring does not exist on the pass side and a regular non electric door cylinder was there should this passenger door have an electric actuator and cylinder hooked up in there? Tu
To C3 1978 Power door locks
