Vacuum in radiator system ? ....2 hoses collapse
5 min. later - both upper & lower radiator hoses COLLAPSED !!! :eek:
What caused this ? -I know there's a vacuum & I'm thinking that there was "air" in the system.
Also, I filled the radiator through the upper hose inlet & filled the exp. tank 1/2 full. Is it possible that the engine had an air pocket ? :confused:
Is there smutz in tank bottom? Is tube too close to tank bottom? Could that tube have a clog? ... or a kink? ... or a collapse under vacuum? ... restricting free-flow back to rad?
BTW, I have Stant pn 331 LeverVent rad cap (16 lb) ... works great with my overflow tank.
[Modified by jackson, 12:34 PM 10/17/2002]
[Modified by jackson, 12:58 PM 10/17/2002]
Not an expert here, but the overflow tank is designed to catch the overflow (neat, huh!) when the system is warm. As the engine cools, the excess coolant is drawn back into the system by way of vacuum. If the hose does not extend to the bottom of the tank, you would suck in air.
Ok....back up.....I've installed an expansion tank from a '66 vette - shouldn't matter, right ?.....ok - maybe I'm the "Dummy" :troll :conehead :hat
So, I 'reversed' the lines ? ....The cap is up, and the line from the rad. feed from the top - Oh :mad :cuss :mad :cuss :cuss ....my fault :nonod:
YIKES !!! I swapped the lines & this just added to my running hot prob., right ?
It should allow the excess coolant (from expansion as it heats up) to flow out to the overflow tank, then as it cools down it should open again from the vacuum created by the cooling to allow that fluid to go back into the radiator (as long as the pickup tube in the coolant tank goes to the bottom, otherwise it will suck air). It sounds like your cap is opening just fine under pressure, but is not opening to allow the coolant to move back into the radiator.
Not sure on the reversed lines, but the system is designed to move the coolant one way, and the flow was affected, it would add to overheating.
So it sucks air instead of water :cuss - but I'll post a re-cap since I'm going home for lunch, I'll see what I can do ! :cheers:
My .02 is on the cap..As i see it its the only thing that could cause this type of probelm.. :cheers: :smash:
BTW, I have Stant pn 331 LeverVent rad cap (16 lb) ... works great with my overflow tank......
However, I'm not ruling out the possibility of a 'defective' rad. cap. Also, I notice that this time I over-filled the system since it leaked a little overflow this time.......
BUT - it's not running near as hot & my oil pressure is where it should be ! :cheers: I'll keep posting updates & check that cap again !!! - this forum rocks. :yesnod: :chevy
The cap was A-ok - 16lbs. of pressure......BUT - :eek: - .....my radiator wasn't completely full ! :cuss
These closed systems are harder to fill than I thought.....so, I took off the upper hose at the neck & held it up while adding water until water squirted out the pass. end at the top 3/8" outlet to the exp. tank.
Now it's full and seems to be working. There might be other issues dealing with heat. :mad .....anything to look for ??? :confused:
I'm checking the following :
* Timing advance (could 'cause engine to operate warm)
* Carb. setup (hafta do this every mo. since it's a Holley :lol: )
* Oil deposits in the water system
* Water pump impeller blades {hafta pull it - last resort}
* Thermostat ? (doesn't have one right now)
* Anything else ???
Virtually all cars should run a t'stat ... or some means of restriction. The restriction is needed to create the backpressure ... without that the pump impellor may not pick up properly. Either put a good t'stat back in ... or you can take a junk t'stat & snip out-gut the center section. A gutted t'stat will provide the needed backpressure with no possibility of a fail-in-closed-position condition. Yea, I know ... there are also t'stats that only fail in open. My point is that some restriction needs to be in the t'stat housing.
Also, you noted that both rad hoses had collapsed ... proving lower hose can collapse. When running, upper hose has pressure and lower hose has suction (pump draws from lower hose). When running you don't want lower hose to collapse as that can restrict flow and cause overheat. Make sure you get a lower hose with a spring in it to prevent collapse. Also, if you have room, double-clamp both ends of both hoses. When running, a pressure leak at top will loose water ... but a vacuum leak at bottom can allow air to be sucked in & that too will cause overheat.
Straight distilled water don't provide corrosion inhibitor nor lube for pump ... 50% antifreeze don't cool so good. So, if you're not in danger of freeze-up ... a good mix is 20% antifreeze:80% DH2O ... that's enough AF to nix rust & lube pump and will elevate boiling point ... BUT it also elevates freezing point.
bubbajack
[Modified by jackson, 2:31 AM 10/20/2002]
I "re-filled" the radiator again leaving the pass. side expansion hose off......and I'm in the process of installing "new" hoses as well. IT's frustrating trying to work out all the bugs :boxing when you're in a "hurry" to see results ! :crazy: :eek: .....ok, deep breath..... Here in TX it doesn't get very cold all too often & I'm sure a 20-30% anti-frz. mix will work just fine......I'm also planning to use a bottle of Redline 'Water-Wetter' ! ;)
