Temperature Sender - 69 Tri power intake
Old Apr 29, 2018 | 10:48 PM
99Silverbullet's Avatar
99Silverbullet
CI 8 & 9 Veteran
C2 of Year Finalist (performance mods) 2019
St. Jude Donor '07-'08
Default Temperature Sender - 69 Tri power intake
Where is the temperature sensor/sender located?
Mine is dated year 69, but no available ports after the coolant fittings.
Is it on the coolant neck? If so where can i find one?
Thanks!
Old Apr 29, 2018 | 10:59 PM
3X2's Avatar
3X2
It is located on the left cylinder head between #3 and #5 exhaust ports. Green wire with an off white connector
Old Apr 30, 2018 | 12:13 AM
99Silverbullet
CI 8 & 9 Veteran
Im running a set of aftermarket aluminim head, trying to find an alternative.
Old Apr 30, 2018 | 05:48 AM
derekderek's Avatar
derekderek
you could use the coolant bypass port on the front of the intake and drill a couple of holes in the thermostat. or... https://www.ebay.com/itm/SBC-BBC-Che...lXiZz9&vxp=mtr
Old Apr 30, 2018 | 12:34 PM
99Silverbullet
CI 8 & 9 Veteran
yep..i think thats they way I'll go. Haven't ran any coolant in the new motor, so best to just swap it before I hook the lines up.
Thanks!
To Temperature Sender - 69 Tri power intake
