Exhaust Comparision help needed
Old May 8, 2018 | 05:37 PM
packavette's Avatar
packavette
Cruising
Default Exhaust Comparision help needed
I recently installed a 383 crate engine (400 hp, 460 ftlbs) and a Tremec TKO 5 speed into my 76, and just hooked up the existing exhaust to save time and get it running. The existing exhaust isn’t completely original, but is stock rams horn manifolds to true duals and flow master mufflers. There is no “x or h” pipe. Some of the piping is original, and has rusted through in a few places.
My question: I like the look of Doug’s or Hooker side pipes, but hear that the long tube headers won’t offer ideal performance, and some of the side pipe inserts are restrictive and steal power. It seems most of these comparisons are between various levels of glass packs or no mufflers at all. Can anyone speak to the performance gains/losses with adding sidepipes as compared to the stock rams horns manifolds?
Im pleased with the performance of my new set up, and would like a rust free exhaust system, but don’t want to lose a bunch of power in the process. If it would be essentially an equal trade performance wise, I’d be good with it. BTW, this car is not raced, just driven occasionally on nice days.
Thanks.
Old May 8, 2018 | 06:00 PM
twinpack's Avatar
twinpack
I was kind of in the same place over the last few months. I decided to go with Hooker Competition headers, Corvette Central 2 1/2" duel exhaust intermediate pipes. The pipes and headers fit great with no issues. The nice think about the pipes is they are correctly bent to fit the factory location in the frame. I also did not buy the pipes with the welded mufflers. I bought the N-11 off road mufflers, again to fit as factory including the rear hanger location. The only thing I had to deal with was the intermediate pipe extensions to mate with the headers. I just brought the chassis to a local muffler shop. The made both connections for $100.00. The nice thing for me and important was the ability to take the system apart. So this method allows for all connections to be secured with SS band clamps and bolts at the collectors. The complete system is out local being ceramic coated inside and out. The headers I bought were just painted for this reason. They were only $203.00 to my door. The pipes were $155.00 plus $24.00 shipping from Keen Products. The muffler were $238.00. for the pair. Again all items were uncoated. The ceramic coating is costing $640.00. I hoping I only do this once. Hope this helps. BTW I had the same concern with the side pipes. I just wanted a good cruiser without a overly load exhaust. My car is a 1968. A little different but this should apply. I was also concerned about heat. I think this approach should help with cabin heat. The company doing the coating say I should see up to 300 F reduction.
Peter
Old May 8, 2018 | 07:50 PM
gerry72's Avatar
gerry72
Originally Posted by packavette
...this car is not raced, just driven occasionally on nice days.
Thanks.
Well, at least you're thinking rationally about this. A couple things to consider.
On the power side, in most cases, the worst header will make more power than the best exhaust manifold. Not an absolute but a pretty safe bet. How much power you leave on the table depends upon the engine and the header design. At your power level, you're probably looking at around a 20 horsepower loss. Maybe more, but not a lot more.
On the practical side, you know the manifolds and exhaust system fit with no weird obstruction or fitment issues. The pipes won't drag on bumps, you can get to the spark plugs, they are durable as cast iron, they don't leak, they are quieter than headers. They are not as sexy as headers, but oh well. Plus you already own the manifolds, so all you need to do are put new pipes on it...and they'll fit without any re-engineering.
If you don't really need the extra power it certainly is something to think about, isn't it?
Old May 8, 2018 | 08:05 PM
flyeri's Avatar
flyeri
Hooker style side pipes are like tomatoes. Some like them and some don't. Personally I do and have been happy with them. When I bought my car it had Hooker Max Flow inserts (glass packs with a 2.5" thru tubes) that all the glass pack was burned out of. I had to wear ear plugs to drive it. I have tried and heard several other inserts and they were either too loud, too quite, or just did not have a good sound. I finally made inserts from an old set of Hookers that I cut both ends off of and used Magnaflow 22" glass packs with 2.25" center cores. At cruise you can carry on a conversation and during acceleration they are pretty aggressive which is pretty standard for Magnaflow.
As to your performance concern you will be better off with a header. Now a set of stepped, tuned headers with 3" exhaust may be better than side pipes, but either will be better than the rams horns. For driving occasionally on nice days, probably any set up will be fine too.
Old May 8, 2018 | 09:24 PM
terry82's Avatar
terry82
I would decide if its all about the looks or the performance.side pipes cant be beat for looks.a great set of headers into a free flowing rear exhaust can sound great and be best for performance.or you can do the old time always works way,,,,,,flip a coin.hahah
Old May 8, 2018 | 11:07 PM
cagotzmann's Avatar
cagotzmann
Thanks.
This tells me is doesn't matter what power it makes or looses. Just get the sound you like with the right muffler setup. X pipe and h pipe change the sound so it may be something to look at, but don't worry about the power you won't notice the difference in the seat of your pants.
To Exhaust Comparision help needed
