1982 Corvette-Cruise Control Release Switch
Old May 13, 2018 | 05:09 AM
biaggio's Avatar
biaggio
Default 1982 Corvette-Cruise Control Release Switch
1982 Corvette-What is a cruise control release switch and where is it located? Thanks
Old May 13, 2018 | 12:22 PM
drwet's Avatar
drwet
You are probably referring to the switch on the brake pedal that releases the cruise control when the brake pedal is depressed. It is mounted up under the dash and is actually two parts. There is an electrical switch which cuts power to the cruise transducer, and a vacuum switch that releases the vacuum.
