engine question
Old May 28, 2018 | 01:56 PM
pats67copo's Avatar
pats67copo
Default engine question
Hi
Hoping someone can help me with a few things. I have a 72 350 coupe and in looking over things in the engine compartment I've come across three things that are confusing me.
1)On the passenger side of the intake manifold mounted to the manifold is a small what looks like cylinder shaped vacuum item with three vacuum line connections and one wire the wire is hooked up but there are no vacuum lines attached.
2)On the passenger side coming out of the wiring harness next to the down tube of the ignition shielding is a blue wire with one female plug attached plugged into that is a green single wire and at the other end the green wires seems to go into something and splices off into three wires that go into a two prong plug that's not connected to anything
3)On the right hand side on the firewall just below and to the right of the hood pin is a plug with three vacuum hoses that go thru the plug into the wiper area. I have one piece of hose that isn't connected to anything on either side.
I have pictures of all of these things downloaded to my computer but can not figure out how to get them on here.
Any help on any of these items would be appreciated
Old May 28, 2018 | 03:12 PM
derekderek's Avatar
derekderek
Hit reply. Then hit go advanced. Then hit manage attachments. Then it is pretty self explanatory.
Old May 28, 2018 | 03:25 PM
bfit's Avatar
bfit
no. Three is the vent from the limit valve.
Old May 30, 2018 | 05:07 PM
kansas123's Avatar
kansas123
See if this answers your questions about #1
https://www.corvetteforum.com/forums...tcs-parts.html
Old May 31, 2018 | 12:16 PM
caskiguy's Avatar
caskiguy
Originally Posted by pats67copo
Hi
https://www.corvetteforum.com/forums...-pictures.html
To engine question
