Hand Brake issues with 1977 L82 4 Speed
I just got my '77 L82 4 speed delivered may 27th. Shipped from Bremerton WA. to Houston TX. It has 70 K miles and has been garaged and pampered by previous owner. My first ride out of the box and the right rear started smoking. I suspect the brake shoes have locked up. I plan to pull the rear wheel off today and take a look. This car has a hard hitting small block ,at 70 mph the tach is showing 3500 rpm's.not great on gas but a lot of fun.
Dementer sole survivor
Received 6,296 Likes
2016 C3 of Year Finalist
sounds like you have a 3:70 rear end. Mine revs about that high around 75 mph. Did you happen to touch the rim to see if it was hot. The heat would transfer and you would know it..
If you jack up the rear end and try and spin the wheels in nuetral you should be able to. When you pull the caliper to get the disc off, look at the return springs, sometimes they get put in on the wrong side. It might not be the parking brake, the caliper could have rusted to the slide, once its freed you just need to add grease
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Another possibility is a locking caliper, not emergery brake at all. Happened to my '68 a couple of times and caused by internally collapsed brake hoses.
Observe the appearance of the rotor if it appears like the caliper pads were dragging.
parking brakes are one of the joys of C3 ownership.....you will invent words when replacing them
Received 1,246 Likes
Compress the little springs and tie them with dental floss.
Install them and then cut the dental floss to let the springs expand.
You may have a bad rubber line. The lines clog up on the inside and don't let the pressure off.
Thanks I will definitely check it out. Previous owner claims to have had all new master cylinder, rotors and calipers recently installed. I did check the flex lines but they are most likely original ones.
Great stuff I feel much better now, can't wait to get dirty and greasy again tomorrow. Houston Weather will be mid 90's and 80% humidity.
some guys tie the springs with dental floss so they are compressed...if you google it you will find a few ways to do it....
I mostly do it with my sons and curse and swear a whole lot and promise to never do it again
