Burned Ignition Coil What To Do
Old Jun 1, 2018 | 02:46 PM
Oldguard 7's Avatar
Oldguard 7
Default Burned Ignition Coil What To Do Update
I burned my ignition coil melting and splitting the insulation on the, and tach wire (see pics on Burned Coil What to Do Next thread) coil wires. I purchased a new ignition coil, coil ground strip, ignition module, distributor cap and rotor, and ignition module. I attempted to start the vehicle Thursday and it did not start. Today I removed the tach wire from the distributor and attempted to start the vehicle. Here is what happened.
My question is what else could be wrong. I know I have to repair the tach wire. I think the vehicle should be running as it did before. Suggestions are definitely welcome. So bring them on.
Old Jun 1, 2018 | 03:10 PM
MelWff's Avatar
MelWff
cannt tell much from that video, is the choke closing?
is the choke pull off working?
It sounds like you have spark at the plugs, did you pull a plug wire at the plug end and check?
did you move the distributor housing while replacing all those parts and changed the timing?
Old Jun 1, 2018 | 06:21 PM
Oldguard 7's Avatar
Oldguard 7
Carb is a BG era mighty demon 750 cfm carb, no choke. Did not pul a plug wire to check for spark
Did not move distributor housing while replacing parts. The vehicle would only run that long
Old Jun 2, 2018 | 01:21 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Well you had spark for a while there to start it. Plenty of spark testers on the market that just touch the plug wire which is easier than pulling a plug, laying on something metal to ground it and looking for spark.
If you don't have spark your ignition is at fault. If you do have spark your problem is fuel/carb.
Reads like your not using a choke and starting would be difficult when cold or fuel bowls low.
Old Jun 2, 2018 | 01:42 PM
carriljc's Avatar
carriljc
Yeah, hard to tell what's going on from that video. I would suggest installing the old module (assuming it is still on one piece), and try again.
You can use an inductive timing light to see if you have spark.
Old Jun 2, 2018 | 09:52 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
sounds like the timing is off. How old is the engine
Old Jun 3, 2018 | 01:55 AM
Oldguard 7's Avatar
Oldguard 7
I rebuilt it in oct 2016, installed it in jan 2017. But did not drive it until week before last to work.
Old Jun 3, 2018 | 08:14 AM
sparky77's Avatar
sparky77
It sounds to me that it could be a fuel problem check the filter ,and take the air cleaner off and look down the carb and see if the accelerator pump is pushing fuel down the carb.
To Burned Ignition Coil What To Do
